Old 05-31-2016, 08:50 PM   #1
Tmielke
Default Alternator belt
I have a 47 flathead that has the converted generator to just a alternator. It's the single belt that runs both water pumps, crank pulley as well as the new style alternator. The old belt and part of the crank pulley were destroyed going down the road. Does anybody have an idea what the belt number is that will work for this application? I know it's the wide style pulley and just running a rope around the path measures about 47". Thanks
Tmielke is offline   Reply With Quote
Old 05-31-2016, 09:25 PM   #2
Ford Freak
Default Re: Alternator belt
I have that setup on a '39 engine . I don't know if the belt measures 47 " or not . I can/will get the # an brand name off the belt for you in the morning .
Ford Freak is offline   Reply With Quote
Old 05-31-2016, 09:34 PM   #3
Tmielke
Thanks, I just don't have a lot info to go off of
Old 06-01-2016, 01:44 AM   #4
1oldtimer
1oldtimer's Avatar
On my '47 it's running a Gates TR22553 (Width (In): 0.688 Inch Outside Circumference (In): 55.910 Inch)
Cross Ref:
Dayco 22555
Goodyear 22560
1oldtimer is offline   Reply With Quote
Old 06-01-2016, 08:12 AM   #5
Tmielke
Thanks
Old 06-01-2016, 08:19 AM   #6
Ford Freak
Goodyear Hi Miler 22550 on mine .
Old 06-01-2016, 09:34 AM   #7
Tmielke
Thanks for the help guys
Old 06-01-2016, 03:07 PM   #8
arc40s
I use a Dayco # B-52 works great.
arc40s is offline   Reply With Quote
