Old 05-14-2016, 07:03 PM   #1
Donpet
Donpet's Avatar
Default Using 12volts on 6 volt starter
Trying to start a rebuilt tight motor. Can I use a 12 volt battery on the starter only to get better turn without hurting the starter? Will a 12 volt turn the engine faster?
thanks
Donpet is offline   Reply With Quote
Old 05-14-2016, 07:06 PM   #2
jacob smith
jacob smith's Avatar
Default Re: Using 12volts on 6 volt starter
I have done it in a pinch and never had an issue. But I really do not know if it will hurt something in the long run
Ford
jacob smith is offline   Reply With Quote
Old 05-14-2016, 07:23 PM   #3
Charlie Stephens
Is there any chance there is a problem with the rebuilt motor? Can you turn it by hand? I think a good 6 volt starter with good grounds and proper 6 volt cables cables should be able to turn the motor without a problem.
Charlie Stephens
Old 05-14-2016, 07:50 PM   #4
woodypecker
woodypecker's Avatar
The 12 volts works great on a 6 volt starter but do not crank very long without cooling time. My guess is no longer than 5 seconds. The tighter the engine the more current the starter will draw and the more likely something will burn in the starter.
woodypecker is offline   Reply With Quote
Old 05-14-2016, 07:52 PM   #5
woodypecker
I should have added do not run through the solenoid. I run 12 volts all the time but have a 12 volt solenoid.
Old 05-14-2016, 09:23 PM   #6
Willit Stop
Willit Stop's Avatar
Bendix springs tend to break. Too much of a shock I guess.I bought two extras.
Willit Stop is offline   Reply With Quote
Old 05-14-2016, 09:41 PM   #7
Donpet
Donpet's Avatar
I found a ground strap from the engine to the frame improved the cranking considerably. So I probably won't need the 12 volts. Thanks for the help.
Old 05-14-2016, 10:58 PM   #8
RalphG
RalphG's Avatar
I've used 12 volts on six volt starters many times over the years. Never broke anything yet and the 52 Mercury definitely turned over twice as fast on 12 volts. I've got it to the point it will start on six volts now.
RalphG is offline   Reply With Quote
Old 05-15-2016, 09:07 AM   #9
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
12 volt system on my 40, 6 volt starter, been on there 40 years, I use a 12 selornid, the 6 volt sel will stick once in awhile. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 05-15-2016, 09:26 AM   #10
Init1
Init1's Avatar
You can use a 12 volt battery with a 6 volt starter. Just don't crank a long time.
If your starter is in good shape and everything else is ready to go
The engine will start quickly.
Also the ground wire inside the solenoid for the single small pin can burn out disabling the push button on the dash.
Stop if anything gets hot.
Init1 is offline   Reply With Quote
Old 05-15-2016, 09:49 AM   #11
JSeery
JSeery's Avatar
I would check that the battery cables and ground strap are the correct size for a 6v system and are in good condition. I would also clean and grease all the battery connects (battery to frame, frame and/or battery to engine and battery to starter solenoid).
Old 05-15-2016, 07:25 PM   #12
packyusmc
packyusmc's Avatar
I used a 6v starter in my 12v converted 38 Tudor till it burned up. Took it to my local starter, gen. Alt. Repair shop. They put 12v guts in the same case, cost about $80.00 and has been working great ever since.
packyusmc is offline   Reply With Quote
Old 05-16-2016, 05:44 AM   #13
fortyfords
fortyfords's Avatar
I may have been lucky on my 40, I used the 6V starter on my 12V system, I even used the 6V solenoid, never had a problem for all the years I ran the car.
fortyfords is offline   Reply With Quote
Old 05-16-2016, 07:41 AM   #14
32phil
12V on my 6V starter in my roadster (rebuilt 8ba). Almost 3K miles now and no problems.
That will probably be the kiss of death.....I'm going to try starting it today after it's winters sleep.....the starter will most likely shoot out across the garage !!!
BUT up till right now no problem with using 12Volts...
Early Ford Lock & Key Service
http://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
