Old 05-12-2016, 12:44 PM   #1
George Miller
George Miller's Avatar
Default Working on engine bearings.
Along the lines of keeping valves in order, the same goes for rod caps and main caps. Rod caps have to go back on the same rods and the same way they came off. Mains same thing you do not want to mix them up. I like to mark them before I take them apart.
One time in my Dads garage a long time ago a young man came in with his engine in pieces. All the caps were in a pile. I was not a happy man. It was a Chev 265 V8, we had a little talk> I seen him about 40 years later and he told me he learned a good lesson that day.
George Miller is offline   Reply With Quote
Old 05-12-2016, 02:53 PM   #2
PC/SR
Default Re: Working on engine bearings.
Yep. The rod caps have the dippers open end pointing to the camshaft. The front and center main caps have a little diamond that points toward the camshaft. Or is supposed to, I have seen them the other way, and if that is the case, re-install them the way they came out. I always number them with magic marker and an arrow toward the front.
PC/SR is offline   Reply With Quote
Old 05-12-2016, 07:32 PM   #3
glenn in camino
glenn in camino's Avatar
Use plastiguage on refitting the caps
glenn in camino is offline   Reply With Quote
Old 05-12-2016, 11:05 PM   #4
Kohnke Rebabbitting
Both dipper, and pinch bolt has to be pointed to the cam side.
Herm.
Kohnke Rebabbitting is offline   Reply With Quote
Old 05-13-2016, 07:31 AM   #5
kenparker
kenparker's Avatar
Herm, what is a "pinch bolt"?
kenparker is offline   Reply With Quote
Old 05-13-2016, 11:07 AM   #6
Kohnke Rebabbitting
The bolt you tighten up on the wrist pin end of the rod to hold the wrist pin in place.
Old 05-13-2016, 07:34 PM   #7
ursus
Rod pinch bolts are a Chevy feature. We are talking Ford here...
ursus is offline   Reply With Quote
Old 05-14-2016, 07:05 AM   #8
goodoldvic
goodoldvic's Avatar
I think Model T rods have pinch bolts on the small end.
goodoldvic is offline   Reply With Quote
Old 05-14-2016, 12:11 PM   #9
ursus
I am showing my ignorance about the Model T, then. I did a lot of messing around with early Chevs before I was saved by the Model A.
