05-04-2016, 06:55 PM | #1 |
Two Questions Repro Bumper Clamp Covers....
Feeling a bit lazy I ordered the SS front bumper clamp covers and the blue decal inserts. I will eventually refurbish the clamps that are on the bumper though I do not think they are original.
(1) Will bending the tabs around the covers suffice to hold them on the clamps as is? They slide on easily and even bending the tabs does not make them fit on real tight. I can grab them with my fingers and with some effort they pull right off. Do folks use some type of glue between the covers and the bumper clamps? (2) The blue decal inserts appear one piece with page and will have to be cut out with scissors. Are they self sticking? Working my way around the whole sheet I cannot seem to separate the decal side from the backing. I will admit to having poor eye sight and arthritis in my fingers! Will call the supplier tomorrow on these questions but would like some input before hand. Thanks... |
05-04-2016, 08:10 PM | #2 |
Re: Two Questions Repro Bumper Clamp Covers....
Figured out the proper way to bend and then install covers!
Also used a single edge razor blade to separate decal page just like bearing shim packs! Thanks for looking..... |
05-04-2016, 08:55 PM | #3 |
In case you want to find something better than the decals, here is what I did after I did not like the decals.
Took a board and drilled holes for the studs to pass through. Level each one both length wise and width wise. Then I went to a hobby store and bought "Model Masters" enamel paint in the tiny bottles. Use the color "Ford and GM Engine Blue" I found this almost dead on to the decal. Then I just used a toothpick to drop on some paint. Wait a few minutes and it will level out (don't put on too much). Here is what it looked like. Bumper Medalions.jpg |
05-04-2016, 09:07 PM | #4 |
Wow, Those look beautiful. Don't have any hobby stores near so I will look on line for the paint. Looks like a great project ! Thanks...
05-04-2016, 10:26 PM | #5 |
The suppliers sell the paint..$4.15.. The stickers suck
05-05-2016, 05:24 AM | #6 |
Did a rough mask of bumper cover recess - sprayed and let it dry. Used acetone on paper towel to remove unwanted paint.
I Love Anything That Turns Money Into Noise |
05-05-2016, 06:36 AM | #7 |
A&L have a small bottle and it matches perfectly for about 5 dollars. The decals are very
Unprofessional. Wayne |
05-05-2016, 08:54 AM | #8 | |
05-05-2016, 09:35 AM | #9 | |
05-05-2016, 11:27 AM | #10 |
The enamel model paint that I used was just of a viscosity that it would level out, but slowly. Just warned that you should not be too fast to keep adding paint. Put a bit on and wait at least three minutes or so to let it spread out, before you just keep adding paint. You can help spread it a bit with the toothpick, but you really want a clean line at the edges and letting it wet out will be the best.
