Old 04-26-2016, 03:21 PM   #1
adileo
adileo's Avatar
Default 1939 Deluxe Coupe emergency brake
Hi Guys
The cable that goes from the wishbone (for lack of right name) to the handle inside the car is starting to separate under the car (a few strands showing).
Can you check my search below? is this the right cable that I need to buy? I don't see where the pin that holds it to the wishbone is from pic
http://www.macsautoparts.com/ford_me...passenger.html
Thanks Andy
adileo is offline   Reply With Quote
Old 04-26-2016, 03:54 PM   #2
40cpe
40cpe's Avatar
Default Re: 1939 Deluxe Coupe emergency brake
This one appears to go through a hole at the handle bracket and at the crossmember and secured by a clip similar to the clip on a brake hose. That is how my '40 worked.
40cpe is offline   Reply With Quote
Old 04-26-2016, 03:58 PM   #3
adileo
adileo's Avatar
My cable is secured at crossmember with this:
http://www.macsautoparts.com/ford_me...roduct_Related
The hole has a pin that has a pin with a cotter pin to hold it in place.
Old 04-26-2016, 04:33 PM   #4
Tom/SC
Tom/SC's Avatar
The cable that you have pictured from macs looks as though it is the right one. Each end of the cable should have a clevis threaded onto each end of the cable. After you install the cable on your 39, each clevis can be adjusted to help you achieve the correct length. The bracket that you have picture here secures the cable to the frame cross member . The cable from the rear backing plates loops thru the bracket you have pictured and is secured to the clevis with a clevis pin and cotter pin and the front of the cable also secures to the hand brake lever with a clevis with a clevis pin and cotter pin. Good looking 39 coupe!
Tom/SC is offline   Reply With Quote
Old 04-26-2016, 04:38 PM   #5
adileo
adileo's Avatar
Thanks Tom for the compliment and the excellent discription/details
I'm think or should I say hoping I can use the old cable to help fish the new one through to inside car.
Your car is a beaut!
Old 04-26-2016, 04:43 PM   #6
JSeery
JSeery's Avatar
This is a 46-48 diagram, but same basic setup.
Old 04-26-2016, 04:48 PM   #7
swoopNZ
MEMBER EMERITUS
According to the original Ford parts book O1C-2853 is the part number.
swoopNZ is offline   Reply With Quote
Old 04-26-2016, 04:51 PM   #8
adileo
adileo's Avatar
Thanks guys that confirms macs number 2853. I just ordered it!
Much appreciated!
Old 05-11-2016, 08:40 AM   #9
adileo
adileo's Avatar
A follow up question. While I'm still awaiting macs to ship......
What is best method for removing old one and installing new one?
- Work from inside back or under side in?
- Can one use the old cable to fish new one through?
Thanks Andy
Old 06-21-2016, 06:30 PM   #10
white64
white64's Avatar
Ok....dumb question time.. (this is embarrassing) since you guys are talking about E-brake cables....
I can't seem to find the right path for it! Around the front of the steering box makes it too short, behind the steering box makes it too long. It appears to be a factory cable... sharp bends impossible!
(Car needs a good cleaning, it's pretty dusty)
white64 is offline   Reply With Quote
Old 06-22-2016, 08:06 AM   #11
Kube
Super Moderator
Kube's Avatar
Not a dumb question at all. The 39 was routed differently than the 40. Here's a couple of photos that I hope will help you.
Look carefully at the interior view and you will note where the cable comes through the floor.
This is the way the factory did it in '39.
Old 06-22-2016, 08:13 AM   #12
Kube
Super Moderator
Kube's Avatar
Originally Posted by adileo View Post
Hi Guys
Thanks Andy
Andy, That appears to be a cable that will fit and function within your car. 01C is the later - service replacement part number prefix.
Old 06-22-2016, 08:44 AM   #13
adileo
adileo's Avatar
Thanks Kube!
Old 06-22-2016, 08:49 AM   #14
RKS.PA
RKS.PA's Avatar
Mike, although this wasn't my question, it's typical of the way you and J Seery come to our rescue with pictures, diagrams, and narrative nearly every day here on the Barn.
You guys are the best!!....and so are many others!!!
Dick.
RKS.PA is offline   Reply With Quote
Old 06-22-2016, 09:14 AM   #15
adileo
adileo's Avatar
Dick.
ECHO that!!
