Old 04-18-2016, 03:11 PM   #1
OL JENNY
OL JENNY's Avatar
Default Which copper head gasket with Snyder's 5.5:1 head?
I have a Snyder's 5.5:1 head on a AER touring engine and I just blew my head gasket. I had a copper B gasket with copper kote on both sides. I have not removed the head yet, but I want another copper gasket and would like to use the one that people have had good luck with. Thanks
OL JENNY is offline   Reply With Quote
Old 04-18-2016, 03:31 PM   #2
loubob
Default Re: Which copper head gasket with Snyder's 5.5:1 head?
Snyder's # B-6051-X Copper
loubob is offline   Reply With Quote
Old 04-18-2016, 03:32 PM   #3
loubob
Spray both sides w/copper gasket sealer before install.
Old 04-18-2016, 04:18 PM   #4
Big hammer
Call AER and talk to Rich, I will send you a gasket that's right for your engine!
Old 04-18-2016, 04:43 PM   #5
Mitch//pa
Rich@ AER uses those silicone modern style gaskets the last time I heard with a 5.5 head
Old 04-18-2016, 06:27 PM   #6
hardtimes
hardtimes's Avatar
Copper 509 fits well.
hardtimes is offline   Reply With Quote
Old 04-18-2016, 08:04 PM   #7
Tom in Newnan
I like the Best brand gasket available from secretsofspeed.com. Not copper, not sure what kind of space age material but highest quality available.
Tom in Newnan is offline   Reply With Quote
Old 04-18-2016, 08:20 PM   #8
amishman
I have an engine rebuilt by AER with 5.5 head, larger intake and exhaust valves, balance crank, Stipe touring cam. Blew a head gasket with only 2000 miles on it, replaced the with the same red silicone bead on it. It blew with less 500 miles. After doing some investigation , decided to try the BEST gasket. Got 5000 miles on this gasket, and all is well. You can get them from Arizona Model A in Chandler AZ or Secrets of Speed Society.
amishman is offline   Reply With Quote
Old 04-18-2016, 08:22 PM   #9
Brian T
Brian T's Avatar
Rich at AER now recommends the Best Co Composition gasket, modern style, this gasket becomes sticky when heated and seals better, and doesn't require copper coat , the failure rate of the silicone gasket is well known.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 04-18-2016, 08:47 PM   #10
Y-Blockhead
Y-Blockhead's Avatar
Is that the Best Gasket "Graphtite" Gasket you used? That's what I have been using exclusively on my Y-Blocks for quite awhile now...
Old 04-18-2016, 08:54 PM   #11
Y-Blockhead
Thanks, answered my own question...
From "Secrets of Speed" website;
BEST GASKET COMPANY: makes our very special cylinder head gaskets like this:
GraphTite™ consists of a Kevlar reinforced graphite facing material is mechanically bonded to both sides of a perforated steel core. This modern engineered, high-performance material is rated to a temperature of 1400 degrees-F. Steel fire rings are installed around the combustion chamber areas of the gasket.
GraphTite™ head gaskets have superb sealing characteristics, excellent torque retention, and hold up to the punishment dished out by high-performance engines – high quality all the way. This gasket might be overkill for cruiser engines, but so what . . extra performance never hurts!
