03-24-2016, 09:16 PM | #1 |
Valve Noise at Startup?
Hey - first time to post and hopefully someone out there can help solve a problem I have been working on. In the process of working out the bugs in my '40 ford pickup. The flathead has about 150 miles on it and recently has developed a ticking noise that sounds like high lash. The odd thing is that it goes away completely after about 2 minutes of idling. I can't pinpoint the exact cylinder, but sounds like its coming from the rear cylinders. Took the manifold off and all valve clearances are spot on. Springs look OK and gave the tappets a turn and they do not feel bound up.
I suspected a stuck valve, but compression check is OK. It does not sound like its coming from the fuel pump. I do have a slight misfire that I think is due to excessive fueling (that's another story). Checking vacuum shows the misfire, but is generally strong and does not change when first started (when it ticks) and after it warms up (no tick). Going to check the exh. manifold tomorrow to make sure nothing is loose/cracked. Any other thoughts? |
03-24-2016, 09:34 PM | #2 |
Re: Valve Noise at Startup?
I would bet a slightly sticky valve. I would run some mystery oil in the gas and see if you can cure it. Gary
I am usually relatively happy------Gary |
03-25-2016, 07:29 AM | #3 |
The sticking valve could explain the slight misfire. Dribbling dome mystery oil down the carb while running works too.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
03-25-2016, 08:52 AM | #4 |
Too much piston clearance?
03-25-2016, 09:15 AM | #5 |
03-25-2016, 09:25 AM | #6 |
03-25-2016, 10:08 AM | #7 |
03-26-2016, 03:57 PM | #8 |
Thanks for the feedback.
I verified that is it not the fuel pump and also checked the exhaust manifold without any issues. Also grounded out each cylinder and there was no noticeable difference - ruling out piston slap. Going to resolve the over fueling next to hopefully fix the misfire before I go further. Pump puts out over 3.5 pounds and have a Holley regulator that should fix it. Any other thoughts is appreciated and I'll post back later on progress. -Mike |
03-26-2016, 08:09 PM | #9 |
Need to put MMO in every once and awhile. If I do not I get the clicking sound on warm up. In the early 50s I worked in a "service station" we always put upluber in the tank.
10-17-2023, 11:46 AM | #10 |
piston slap is usually heard under load it would have to be real bad to do that
10-17-2023, 02:18 PM | #11 |
This is an old post and the OP said he would check back later with the progress. I suppose he is still working on it?
10-17-2023, 07:58 PM | #12 |
It's only been 7 1/2 years....give the man a chance!
Terry
10-17-2023, 08:20 PM | #13 |
mrboch was last logged in here 8-20-22.
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I DONE TODAY... I put my rear-end in the recliner, and now I'm going to rest up & watch TV. |
10-18-2023, 02:01 PM | #14 |
You have options #1 take it apart and check everything, #2 Drive it fir awhile, might go away, #3 ?????
Gramps |
