03-22-2016, 10:21 PM | #1 |
Intake and fuel pump mount help.
Hello All. I'm working a my LB rebuild and have questions, I have both a cast iron and aluminum intake. I understand the aluminum is the "right" one to use, but when I go to install the sleeve you slide in before the fuel pump mount stick out too far. Or is this only installed with the cast iron? I see its taller where the pump mount is installed Please guide.
03-23-2016, 12:50 AM | #2 |
Re: Intake and fuel pump mount help.
There is a shorter sleeve and push rod for your aluminum intake.
03-23-2016, 06:04 AM | #3 |
We've got both sizes of the sleeves and the pushrods.
03-23-2016, 06:42 AM | #4 | |
If you have not yet found a short baffle tube, I have some of these that I won't be needing. PM me if you should have an interest.
