Old 03-06-2016, 01:01 PM   #1
Kube
Super Moderator
Kube's Avatar
Default 1940 Ford convertible body tags
I'd like to hear from guys with '40 Ford convertibles...
Is there or, to your knowledge, was there, a body tag on your vehicle? Or, are there numbers stamped in to the firewall?
I have posted two photos below that allow a glimpse of where a tag should have been and a glimpse as to where numbers may have been stamped.
Please, if you are able to respond, allow as much as you know in regard to your vehicles 'pedigree".
The tag was "nailed" to the upper- left corner of the firewall. Stamping was below the voltage regulator.
thanks!!!
Old 03-06-2016, 02:09 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: 1940 Ford convertible body tags
Mine had a tag. I didn't reinstall it because at the time when I built that car I wasn't very concerned with being too correct. I still have it somewhere.
Ken/Alabama is offline   Reply With Quote
Old 03-06-2016, 04:27 PM   #3
Kube
Super Moderator
Kube's Avatar
Thanks Ken. That's one response. C'mon guys... please....
Old 03-06-2016, 04:47 PM   #4
Bill
Bill's Avatar
Is it possible that those convs with the tag would also have the stamped # under the voltage regulator? Just asking. Bill
Bill is offline   Reply With Quote
Old 03-06-2016, 05:26 PM   #5
Kube
Super Moderator
Kube's Avatar
Not sure Bill. I have only heard "hearsay" about the cowls being stamped. Documents indicate a body tag was to be attached. I am attempting to find out what in reality happened back then.
Old 03-06-2016, 07:42 PM   #6
deuce_roadster
deuce_roadster's Avatar
No tag, no stamped number. VIN * 18-5712258 *
I am the first owner of this car outside of the family that bought it new.
Anybody else?
Old 03-07-2016, 08:21 PM   #7
KSFORTYFORDS
KSFORTYFORDS's Avatar
Mine has a body tag on it, the car was partially restored when I bought it out of Minnesota in 2006.
KSFORTYFORDS is offline   Reply With Quote
Old 03-15-2016, 06:54 PM   #8
Milt/Las Vegas
Milt/Las Vegas's Avatar
I checked the convertible project which has the original paint on the firewall no tag never had one and no stamping underneath the voltage regulator.They all have the holes for the tag but no tags.The other 40 convertible I'm building which was a pretty original complete car had no tag and the firewall wasn't stamped.
Milt/Las Vegas
Milt/Las Vegas is offline   Reply With Quote
Old 02-11-2019, 11:26 AM   #9
Automotive Stud
Automotive Stud's Avatar
I know this is old, but for what it's worth I just saw the thread and checked my car. There is no tag and no signs of there being a tag. My car has the original paint on the firewall.
Automotive Stud is offline   Reply With Quote
Old 04-17-2021, 10:18 PM   #10
woodiedude
woodiedude's Avatar
I recently acquired a 40 Convertible and I saw this post. I am new to the group but I will try to attach a picture of my engine that has a body tag mounted with four nails. The tag has been painted over and I didn’t try to remove any of the paint. I can get more pictures if needed next week.
File Type: jpg 3DF9E9A1-A2A3-4CDC-9718-636491A72FF1.jpg (42.7 KB, 119 views)
File Type: jpeg 697E3B49-2167-4CAF-99D5-F1339C899092.jpeg (133.5 KB, 129 views)
File Type: jpg 2B7096D1-E4BB-4365-9E16-B7BC99D35238.jpg (42.6 KB, 107 views)
woodiedude is offline   Reply With Quote
Old 04-18-2021, 04:43 AM   #11
swoopNZ
MEMBER EMERITUS
One of my 39 deluxe convertibles ( ex USA ) had a body tag up in the LH corner.
From memory it ended with 074 indicating the first week of production.
swoopNZ is offline   Reply With Quote
Old 04-18-2021, 06:28 AM   #12
Terry,OH
Terry,OH's Avatar
Like woodiedude in #10 above here is another early firewall you can see the four holes for mounting the patent data plate over the hand throttle bump out, on the vertical surface. Ill ask the mechanic if there are numbers or a body tag.
The mechanic says there are no numbers on the firewall. The old paint was stripped for repaint so any numbers would have been seen.
File Type: jpg 40 early firewall with tag above hand throttle bump.jpg (49.9 KB, 84 views)
Terry,OH is online now   Reply With Quote
Old 04-18-2021, 08:05 AM   #13
Kube
Super Moderator
Kube's Avatar
That's the patent tag.
I've attached a photo of a body tag - this one on the last '40 convertible I'd restored.
Old 04-18-2021, 11:43 AM   #14
40larry
thanks!!!
The tag riveted to upper edge of firewall in second photo doesn't look like a body number tag and body number. I have no such tag or any body tag on my 40 conv. For what it is worth my 40 wagon firewall has the body number stamped into firewall under lower edge of voltage regulator.
40larry
40larry is offline   Reply With Quote
Old 04-18-2021, 12:22 PM   #15
Kube
Super Moderator
Kube's Avatar
40larry
Larry, Which post are you referring to ("second photo")?
Old 04-20-2021, 12:08 PM   #16
40larry
Sorry. I should have said left side photo with tag on upper right of firewall.
Old 04-20-2021, 01:24 PM   #17
Kube
Super Moderator
Kube's Avatar
Which post number?
Old 04-20-2021, 01:40 PM   #18
40larry
Which post number?
Post No. 1 Your opening post. I think that our problem is which side is left and right. On your opening photo on left side of your posting there is a tag attached with drive nails on the upper part of firewall. The tag is on upper left side of the firewall and upper right side in the photo. What is on that tag?
Old 04-20-2021, 02:14 PM   #19
V8COOPMAN
V8COOPMAN's Avatar
Kube....In ref to Larry's question, I'm assuming this is your blue coupe in your avatar. Didn't you once note that this number was the SERIAL for this "special-order", lawman's coupe? I believe it started with a "P". Or am I full of it once again? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-20-2021, 02:23 PM   #20
40fconvt
My 40 convert purchased well used in 1955 with pull out ashtrays has three small holes but no tag.one hole would have hidden under the tag.
40fconvt is offline   Reply With Quote
