Old 03-06-2016, 11:40 AM   #1
46fordnut
46fordnut's Avatar
Default tump
hi fellas...i was at a local car show yesterday . i was only like 30 deg . so i only stayed for and hour . on the way home i was doing around 40 out of nowhere i got a big thumping noise from one of my front tires. pulled over found nothing . my tire are kinda old but still have life left . bias type . took car back out today noise gone . flat spot in a tire or maybe wheel bearing? thanks in advance
if rust were money i would be a billionaire!!
46fordnut is offline   Reply With Quote
Old 03-06-2016, 12:40 PM   #2
adileo
adileo's Avatar
Default Re: tump
Both front tires or just one? If one maybe a rock caught in tread?
Also curious (I'm in NJ) where was show?
adileo is offline   Reply With Quote
Old 03-06-2016, 12:55 PM   #3
Bill S
Default Re: tump
If real old tires could be nylon. When the car would sit and it was cold the tires would have a flat spot until the tires warmed up.
Bill S is offline   Reply With Quote
Old 03-06-2016, 01:48 PM   #4
46fordnut
46fordnut's Avatar
Default Re: tump
just one . but at the show my one wheel was on an uneven spot.
Old 03-06-2016, 01:49 PM   #5
46fordnut
46fordnut's Avatar
Default Re: tump
im in central nj.
Old 03-06-2016, 02:03 PM   #6
VeryTangled
VeryTangled's Avatar
Default Re: tump
Originally Posted by 46fordnut View Post
my tire are kinda old... bias type...
Hi Everyone, 46fordnut, Just my opinion here, but after about six or seven years I change my bias tires regardless of wear ('36 Phaeton, 600x16). I expect my car to be able to drive 300 mi. a day (or weekend) easily whenever I wish to. Seems expensive and wasteful but I look at it as the cost of confidence. I vote for new shoes for baby. But what do I know?
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 03-06-2016, 02:24 PM   #7
Marv
Marv's Avatar
Default Re: tump
Maybe the tire has a separation and the bubble bursted. If i am right and you wind the old girl up to 55 you will hear a slapping noise.
Marv is offline   Reply With Quote
Old 03-06-2016, 02:38 PM   #8
ford38v8
ford38v8's Avatar
Default Re: tump
You picked up a hitchhiker who wasn't going far.
Alan
Old 03-07-2016, 12:31 AM   #9
46WINE
Default Re: tump
Sounds like ply separation in one of your tires. It's happened to me and took along time to figure out. Good luck
46WINE is offline   Reply With Quote
Old 03-07-2016, 10:19 AM   #10
RalphG
RalphG's Avatar
Default Re: tump
I had that "thump" on a radial tire on a newer vehicle a few years ago. It did not go away. Jacked it up and rotated the wheel and there was an obvious bulge in the tread showing that ply separation was happening. The tire was finished. Although it still had plenty of tread.
RalphG is offline   Reply With Quote
