Old 02-26-2016, 12:40 PM   #1
Deuce Man
Deuce Man's Avatar
Default Noisey speedo
The speedometer in my 46 makes a racket when it is cold, quiets down after 10 miles or so. I have it disconnected for now. Is there an easy lube fix in place, or do I have to pull it out? Thanks Rich
Deuce Man is offline   Reply With Quote
Old 02-26-2016, 12:57 PM   #2
tonydennisadw
Default Re: Noisey speedo
mine did same thing when cold out i got lucky unscrewed from speedometer end carefully put cable back in tightened back up and hasnt done since and its been cold here in oh not only did it make noise but needle jumped with it.......
tonydennisadw is offline   Reply With Quote
Old 02-26-2016, 01:57 PM   #3
Jack E/NJ
Jack E/NJ's Avatar
A bit of sewing machine oil allowed to dribble down the speedometer end can help if it needs more lube. However, it could also be due to the cable being a bit too long in its sheath (or the cable ends not fully seated) which tends to bunchup/bind the cable and also result in a tick and/or an erratic needle particularly at low speeds.
Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 02-26-2016, 02:05 PM   #4
rotorwrench
rotorwrench's Avatar
The rotating magnet is a relatively close fit to the drag cup that is attached to the needle & spring. On older instruments with some wear on the bearings, the cup can drag against the magnet until things get warmed up and expanded to normal size. The bushings can also get noisy when they have been dry too long. Many of these old units have an oil wick that can be accessed and re-oiled if you know where to look for it.
Old 02-26-2016, 04:30 PM   #5
flatheadfan
flatheadfan's Avatar
Here is a picture of a '35 Delco speedometer oil wick.
Tom
flatheadfan is offline   Reply With Quote
Old 02-27-2016, 12:17 AM   #6
fordor41
fordor41's Avatar
Tom
Exactly. My guess id the bushing is dry. Oil will probably do wonders. Fords also have that wick hole. I remove the speedo, run it slowly with a battery drill and feed oil into the wick. Always seems to work for me.
fordor41 is offline   Reply With Quote
Old 02-27-2016, 12:00 PM   #7
19Fordy
19Fordy's Avatar
Be sure to have the cable horizontal with no bends as it screws into the speedo.
Support it with a wire tie.
Old 02-27-2016, 02:56 PM   #8
Johnnydidd
Johnnydidd's Avatar
I used 3 in 1 oil took while but quit noise after a couple days.
Johnnydidd is offline   Reply With Quote
Old 02-27-2016, 05:48 PM   #9
Deuce Man
Deuce Man's Avatar
Jack E, I think you had the answer. I put the cable back on the speedometer and left it a few turns shy of bottoming. Took it for a ride and it was absolutely silent. Thanks guys! Rich
Old 02-27-2016, 07:56 PM   #10
Ken/Alabama
Ken/Alabama's Avatar
Pull the speedo out and remove it from the housing then lube it. It's not that big of a job. Then pull the cable from the housing and wipe it down with grease then slide it back in the housing.
Ken/Alabama is offline   Reply With Quote
