Old 01-14-2016, 03:51 PM   #1
Bill in SoCal
Bill in SoCal's Avatar
Default Gas Gauge Inner Nut
The picture is of the gas gauge from my early 30 coupe. Notice the inner nut. The standard tools I have do not fit. They fit a 5/8 opening. Mine has a 21/32 opening for the tool. The lens in the middle is smaller and does not appear to have a face plate behind it. I looked in the judging standards and did not find it mentioned (maybe I was speed reading).
I am curious about this nut. What can you guys tell me about it? Bill
Bill in SoCal is offline   Reply With Quote
Old 01-14-2016, 07:01 PM   #2
larrys40
Default Re: Gas Gauge Inner Nut
Bill,
Hard to tell but it looks like it has the points on it like the standard inner nut... If so get yourself one of the repro aluminum inner/outer wrench sets. If it only has four points you can make a tool to do the job. My suggestion is to make sure your fuel level is down below the gauge and remove the outer nut which will remove the gauge assembly and then you can deal with it on the bench. It may need to be replaced. You can determine once off. Once out you can soak the inner nut with penetrant to help loosen and even a little light heat from a heat gun to help loosen the hold on it from the old fuel.
Once apart you can proceed with restoring the assembly.
Larry Shepard
larrys40 is offline   Reply With Quote
Old 01-14-2016, 08:14 PM   #3
700rpm
700rpm's Avatar
Also disconnect the battery any time you're opening up the gas gauge.
Ray Horton, Portland, OR
Old 01-14-2016, 08:49 PM   #4
Gary WA
Gary WA's Avatar
Wrenches:available from Model A Parts suppliers.
www.whidbeymodelaclub.com
Old 01-14-2016, 09:01 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I like to remove the gauge as Larry said, then I remove the pin and arm so I can lay the gauge on a 1 x 4 clamped in the vice. This way I can put a lot of down pressure and twisting force on the inner nut, and not damage the gauge body.
Old 01-14-2016, 10:00 PM   #6
Synchro909
Synchro909's Avatar
Those aluminium tools sold by the vendors are rubbish. I made a set myself. Much easier to use and cost nothing (but a little time and some scrap)
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 01-14-2016, 10:35 PM   #7
Gary WA
Gary WA's Avatar
Not all are machinists,but they do work for as many times as its needed. Do you have a photo of your custom made one to share. thanks gary.
Old 01-14-2016, 11:09 PM   #8
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
No aluminum here;
Mikes Afordable
Old 01-14-2016, 11:10 PM   #9
Bill in SoCal
Thanks for the information on inner nut removal, but I am more interested in the inner nut than how to remove it. The inner nut is a six point not and eight point nut. The standard tools (as you can see in some of the pictures) remove an eight point nut. The lens in the middle is smaller and does not appear to have a face plate behind it. I looked in the judging standards and did not find it mentioned.
Can someone help identify the inner nut? Bill
Old 01-14-2016, 11:18 PM   #10
Bill in SoCal
Bigger Pictures
Old 01-14-2016, 11:23 PM   #11
al's28/33
al's28/33's Avatar
you are going to have to fabricate something from square steel tubing....be patient and make sure the fit is dead on perfect or you'll strip the whole thing.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
