01-09-2016, 01:15 PM | #1 |
overdrive relay modern replacement?
On my 58 County Sedan, I need to replace a missing overdrive relay. Is there a modern replacement or something else that will work? The few I have found on line as OEM replacements must be made of unobtanium based on how they're priced...
thanks Bill |
01-09-2016, 02:47 PM | #2 |
Re: overdrive relay modern replacement?
A start-run relay for a late 60s/early 70s Chrysler works just fine and at a substantial discount below the repop OD relays.
01-09-2016, 04:32 PM | #3 |
thanks Dobie
01-09-2016, 04:47 PM | #4 |
I used one from Radio Shack.It doesn't look anything like the original,but it works just fine and only cost about $6.
Paul H. |
01-09-2016, 06:53 PM | #5 |
Any standard Bosch style ISO relay rated at 30 amps or higher will live a long life. $1-2 online (depending where you look), $6-$10 at your local parts place or dang near free by the handful at the junkyard - just grab a bunch from an underhood fuse block and pay the man a few bucks.
01-09-2016, 08:46 PM | #6 |
