12-29-2015, 02:14 PM | #1 |
Reverse Wheels
Not wanting to side track a previous thread on wheels I will ask this question here.
Ok I am going to show my ignorance here. For more years than I can remember I've heard the term "reversed wheels". Chrome wheel shops used to advertise "chrome reverse wheels". Looked like an ordinary stock wheel only chromed. What is the difference, advantage, benefit or attraction of reversed wheels?
https://www.youtube.com/user/roosty6/videos |
12-29-2015, 02:17 PM | #2 |
Re: Reverse Wheels
The centers are drilled out (where they rivet to the outside rim) reversed and rivet it back in. It gives more of a "dished" look and moves the tire outboard.
12-29-2015, 02:51 PM | #3 |
Re: Reverse Wheels
The wheels that I reversed were to give more clearance so that wider tires could be used.
12-29-2015, 06:53 PM | #4 |
Re: Reverse Wheels
Thanks for the info. I guess tire clearance would be an issue when using that type wheel. Wider tracking, maybe a little heavier steering in the days before power steering.
12-29-2015, 07:50 PM | #5 |
Re: Reverse Wheels
Reversed rims or deep dished rims are often used with shortened rear axles and wide tires on fender less cars. You would not want to use a lot of dish on a front tire, it would throw the scrub line off.
12-30-2015, 09:48 AM | #6 |
Re: Reverse Wheels
Scrub line refers to the imaginary line between the bottom of the front and rear rim that you don't want anything hanging below. Or at least that's how I learned it. T |
12-30-2015, 10:26 AM | #7 |
Re: Reverse Wheels
Back when i worked at the "service station" we reversed a lot of wheels. Most wheels back then had riveted centers. We cut these rivits with a air chisel, knocked the center part out and turned it around reversing the outer section.
I had a 50 plymouth coupe that we knocked the center section out and put the center in a buick wheel. The Buick was a wider rim and looked pretty cool on the coupe. Typically we bolted the rim center back in the rim and installed a rubber liner to cover the bolt heads to prevent damage to the tube. Station wagon rims were always wider than regular car wheels and worked very well . A few summers ago i dropped off a wheel and tire to be fixed for a flat tire . I returned to pick it up and was told "we dont do tubes"......then i took it to a local firestone and returned to be told we dont fix any tire we didnt sell !!! I fixed it my self...... |
12-30-2015, 10:27 AM | #8 |
Re: Reverse Wheels
Sorry, used the wrong term. Should have said Scrub Radius!
12-30-2015, 10:38 AM | #9 |
Re: Reverse Wheels
One thing you have to watch out for is scrub radius,caused by king pin inclination. This will put an added load on the spindle and sreering box. Like T said
12-30-2015, 11:17 AM | #10 | |
Re: Reverse Wheels
12-30-2015, 12:08 PM | #11 |
Re: Reverse Wheels
Just a reminder for anyone thinking of replacing rivets with bolts, rivets swell and cause an interference fit, bolts do not, and will loosen in time.
12-30-2015, 12:30 PM | #12 |
Re: Reverse Wheels
I guess, given enough time they might loosen. They haven't so far, but then it's only been 35 years. (BTW, I did use fine thread grade 8 bolts and lock nuts as well.)
12-30-2015, 03:55 PM | #13 |
Re: Reverse Wheels
In 1962 I reversed the wheels on a 1940 standard 2 door. Cut the rivet heads with a gas torch . Gas welded the insides to the outsides of the wheels. The rich guys had, chrome reverse. We just painted them - we were cool then. Would I do it that way today ? Hell no, but I was 18 then. Remember how that worked ?
12-30-2015, 04:02 PM | #14 |
Re: Reverse Wheels
I think I might have started this whole thing with my post on a previous thread. Back when I did it, it was strictly for looks. I eventually made a set of wheels with Ford centers and Buick rims so I could run BIG tires in the rear of a "T" bucket I built, but in the beginning it was just because they looked cool.
12-30-2015, 04:17 PM | #15 |
Re: Reverse Wheels
This pic shows a pretty good example of a BEFORE and two AFTERS, on the same type wheel. Note that the valve stem is on the outside of the original (BEFORE), as it should be. DD
12-30-2015, 05:53 PM | #16 |
Re: Reverse Wheels
This about drove my Dad crazy one time when he had to air up a tire and couldn't find the valve stem -- it was on the inside!
12-30-2015, 05:57 PM | #17 |
Re: Reverse Wheels
Sure do look nice.
12-30-2015, 06:06 PM | #18 |
Re: Reverse Wheels
just a cool coat of paint and some baby moons, maybe the chrome rings if you really had some $$. wonder how much that would have been in about
1964 |
12-30-2015, 06:58 PM | #19 |
Re: Reverse Wheels
As I remember baby moons were about $6 a set.
12-30-2015, 07:49 PM | #20 |
Re: Reverse Wheels
Hey, Jim, Treadquarters or Mr Tire will mount my hotvrod wheels. Made a deal with the manager and I pay cash so there is nothing liability to them. Love me you, no one else would do it. Most used tire places will do it as well ..
