Old 12-25-2015, 07:03 PM   #1
Jakno
Jakno's Avatar
Default 35 Pickup Hood Emblems
Cleaning up parts to re-assemble the 35 pickup. These Hood emblems need some help. The 3 small threaded rusty bolts have smooth oval heads and must have been pressed in or a carriage head type. Can they be replaced or should I deal with them in place ?. Also are the emblems all chrome ?. No blue background ?. Thanks
Lineman, the only dumb animal that can harness himself !!
Jakno is offline   Reply With Quote
Old 12-25-2015, 07:42 PM   #2
Vanspeed
Vanspeed's Avatar
Default Re: 35 Pickup Hood Emblems
I think the background was blue as mine show remnants of it. I would try to save the fasteners if you can.
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 12-25-2015, 09:33 PM   #3
V12Bill
V12Bill's Avatar
For my 1939 PU i bought some #8- 32 stainless carriage style bolts. I forget where I bought them, but the #8 size was an odd ball as most suppliers only went down to a #10.
V12Bill is offline   Reply With Quote
Old 12-26-2015, 07:56 AM   #4
flat-v8
flat-v8's Avatar
The original ones are solid brass just plated chrome, I know cause I've tried cleaning up some with steel wool and yellow comes thru. Any of them that have a blue background are re-pops. I f you look around you can find solid chrome originals, there are 3 threaded studs for mounting, 8/32?
flat-v8 is offline   Reply With Quote
Old 12-26-2015, 08:23 AM   #5
Don Rogers
Don Rogers's Avatar
Jakno, The original Emblems were stamped brass with a bright chrome plating. The recess areas were painted blue. The studs had 6-32 threads. This information is highlighted on the attached drawing from the Benson Ford Research Center.
Don Rogers is offline   Reply With Quote
Old 12-26-2015, 08:39 AM   #6
Jakno
Jakno's Avatar
Thanks everyone. The knowledge on here & the access to it is amazing.
Old 12-26-2015, 04:11 PM   #7
Matt in Alameda
I have a '35 coupe and zero in on anything that Don Rogers says.....and I get a kick out of all the answers posted that are all over the place, and then he posts, and WHAM! discussion over! We are soooo lucky to have this site.....Matt in Alameda
Matt in Alameda is offline   Reply With Quote
Old 12-26-2015, 06:39 PM   #8
Vanspeed
Vanspeed's Avatar
Mine are originals, I have records back to '61, and have remnants of the blue paint so I know they were painted. Don has the proof above.
Old 12-26-2015, 09:48 PM   #9
Lawson Cox
Lawson Cox's Avatar
Again. Don comes through as the Guru of all things 35-36.
