Old 12-25-2015, 08:00 AM   #1
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default pressure plate bolts
Where can I buy some of those 5/16 shouldered pressure plate bolts that bolts the pressure plate to the flywheel. Would like to buy a couple doz. Thanks Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 12-25-2015, 08:46 AM   #2
gajeepguy
Default Re: pressure plate bolts
NAPA, ask for ford pressure plate bolts.
gajeepguy is offline   Reply With Quote
Old 12-25-2015, 08:52 AM   #3
oldford2
oldford2's Avatar
Walt,
Roy Nacewicz listed them in his catalog. 734-654-9450.
Merry Christmas. John
oldford2 is offline   Reply With Quote
Old 12-25-2015, 09:56 AM   #4
40cpe
40cpe's Avatar
those are listed for '37-'48. Are 8BA style different?
40cpe is offline   Reply With Quote
Old 12-25-2015, 04:48 PM   #5
Walt Dupont--Me.
I believe there all the same 5/16 Merc are 3/8. Walt
Old 12-25-2015, 05:50 PM   #6
Lawrie
Lawrie's Avatar
Walt we use ARP ones ,if you want let me know and I will get you the part number.
Lawrie
Lawrie is offline   Reply With Quote
Old 12-25-2015, 06:03 PM   #7
Bored&Stroked
Bored&Stroked's Avatar
Lawrie
Same with me . . . I get them from Jegs.
Old 12-25-2015, 08:22 PM   #8
Walt Dupont--Me.
I just looked them up in a Jeg cat, $11.00 each, does that sound a little high? Walt
Old 12-25-2015, 09:27 PM   #9
Krylon32
Walt: While it doesn't say so I think that is the price for 6?
Krylon32 is offline   Reply With Quote
Old 12-26-2015, 08:04 AM   #10
Walt Dupont--Me.
That sounds a little more better, Thanks Krylon. Walt
Old 12-26-2015, 10:15 AM   #11
Ronnie
Ronnie's Avatar
http://www.jegs.com/p/Mr-Gasket/Mr-G...48892/10002/-1
R
Ronnie is offline   Reply With Quote
Old 12-27-2015, 11:26 AM   #12
chuck stevens
chuck stevens's Avatar
Walt, I have made them out of grade 8 bolts. They were 1 1/2 long with a unthreaded section just below the head, shorten them to the ford bolt size and make sure they don't bottom out. Use the ford bolts as a pattern. A new hacksaw blade is a big help, Chuck S.
chuck stevens is offline   Reply With Quote
Old 12-27-2015, 09:15 PM   #13
Walt Dupont--Me.
The 48 and older wheel, the pressure plate holds in the wheel are not drilled all the way through, so, it's hard to find a bolt with the correct length shoulder and cut the thread to length. I don't know why Ford didn't drill the holes all the way through like the did in the 8BA wheel. Walt
