Old 12-09-2015, 06:30 PM   #1
Don
Don's Avatar
Default 49 larger size water neck for the hoses on early cars
I saw in one of the parts catalogue awhile back that someone had the larger water neck on the 8 ba engines where you didn't have to make some kind of bushings to go to the larger hose,any help here????
DON P
Don is offline   Reply With Quote
Old 12-09-2015, 06:45 PM   #2
Binx
Default Re: 49 larger size water neck for the hoses on early cars
Here...
http://www.honestcharley.com/hot-rod...num-49-53.html
Lonnie
Binx is offline   Reply With Quote
Old 12-09-2015, 07:19 PM   #3
Don
Don's Avatar
That's it,a little pricy tho...cast iron or alum um
DON P
Old 12-09-2015, 07:21 PM   #4
Don
Don's Avatar
Just wondering if they make a hose swedged down to the 1/14 size,,
DON P
Old 12-09-2015, 07:28 PM   #5
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I just cut off a piece of 1-1/4 hose, slip it over the 8ab housing then use the 1-3/4 hose to the radiator. It works fine and a lot cheaper. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 12-09-2015, 07:39 PM   #6
TJ
TJ's Avatar
Speedway has them in their catalog.
Old 12-09-2015, 08:33 PM   #7
paul2748
paul2748's Avatar
I used this method too. No leaks
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 12-09-2015, 08:55 PM   #8
Don
Don's Avatar
I have made a bushings also using a smaller dia hose,worked ok,will look at speedway,don't have there latest catalogue
DON P
Old 12-10-2015, 06:38 PM   #9
slowforty
Drake has them in the Holiday catalog
slowforty is offline   Reply With Quote
Old 12-10-2015, 08:24 PM   #10
oldford2
oldford2's Avatar
Listen to Walt unless you want to spend extra $$. Keep it simple.
oldford2 is offline   Reply With Quote
