Old 12-04-2015, 04:29 PM   #1
221239ford
Default 6 volt heater motor
I am looking for a source to either rebuild my 6 volt, two-speed heater motor for my '41 or to buy a new one. It reverses direction for heat or defrost. Any ideas?
221239ford is offline   Reply With Quote
Old 12-04-2015, 06:13 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: 6 volt heater motor
Post measurements of motor. I have one that I think is 40 ford, but not sure. Yours for shipping.
Old 12-05-2015, 09:55 AM   #3
221239ford
Thanks, Lawson. The motor measures 2 3/4" wide, 3 1/2" front to back, shaft is 3/4", posts to mount to heater are 2 1/4" center to center.
Ted Wilburn, Early Ford V-8 Club, Charlotte.
Old 12-05-2015, 12:08 PM   #4
V8 Bob
V8 Bob's Avatar
Check out the 6 V Balkamp #655 1021 from NAPA. Very close to the '41 in size. I'm using the 12 V version #655 1022 in my '41-'48 heater. Just need a reversing switch to go from heat and defrost.
V8 Bob is offline   Reply With Quote
Old 12-05-2015, 07:49 PM   #5
221239ford
Thanks for the advice, Bob. I will check it out. I have a reversing switch.
Old 12-06-2015, 04:24 PM   #6
221239ford
Bob, is this a two speed motor or does it just have two wires? I went my local NAPA this afternoon and they pulled the part # up and the picture that appeared looked like an artist's rendering showing a two wire motor. My reversing switch has low and high in each direction.
Old 12-06-2015, 04:32 PM   #7
flatheadmurre
flatheadmurre's Avatar
How many wires go into your motor today ?
If you have 2 wires the low speed is a resistor in the switch.
Old 12-06-2015, 05:00 PM   #8
flathead48
Ford motor has 3 wires plus ground. Hope this helps.
flathead48 is offline   Reply With Quote
Old 12-06-2015, 05:57 PM   #9
V8 Bob
V8 Bob's Avatar
The #655-1021 and 1022 motors are both reversible 2 wire single speed. I am using a 3 position/speed blower resistor I found on E__y, along with a toggle reversing switch.
Just enter the model number on the NAPA web site to see the motors.
Blower Motor - AC / Heater Part Number: BK 6551021
Product Line: Balkamp
IMPORTANT INFO: 6 Volt
Add to Compare
Attributes: Blower Motor Rotation : Reversible
Case Bolts Center To Center (G) : 2 5/16"
Case Mounting Face To Mounting Face (C) : 2 7/8"
Outside Motor Diameter (D) : 3"
Overall Motor Length (B) : 3 3/4"
Shaft Diameter : 1/4"
Shaft Extension From Face (A) : 1 13/16"
Voltage : 6 Volt DC
Warranty:
Old 12-06-2015, 06:49 PM   #10
221239ford
Thanks, all. I will continue to look for a two-speed reversible motor like I have (3 wires to switch plus ground wire).
Old 12-06-2015, 11:23 PM   #11
Drbrown
Drbrown's Avatar
I assume your motor is defective. There are people that rebuild electric motors. Most of these fellows survive by servicing industrial motors but usually have the skills to fix any kind of motor. I had one rebuild a 1948 shop motor and they were very reasonable. These kinds of shops may be hard to find so one has to be persistent in looking.
Drbrown is offline   Reply With Quote
Old 12-08-2015, 11:22 PM   #12
Lenny51
Lenny51's Avatar
Try looking in Hemmings Motor News for some one to rebuild your heater motor
or let me know and I could look it up for you I get the magazine every month
Lenny51 is offline   Reply With Quote
Old 12-09-2015, 06:52 PM   #13
Lawson Cox
Lawson Cox's Avatar
Ted: I finally got around to looking at the motor I have, It is a two wire, 3" in length, 2 3/4 circumference and 3/4 shaft, However, there are no mounting studs or bolts, but it requires a band around it with a rubber strip that goes between the mounting strap and the motor itself. I would post a photo, but have lost my ability to do that. Doesn't seem like what I thought it was however. still yours for shipping if you want it. Lawson
Old 12-10-2015, 02:11 AM   #14
flatheadmurre
If youre looking for a shop to have it rewound, look for people redoing small motors like hand tools.
Companies doing regular 3-phase motors usually dont like brushed motors to much.
Should be possible to adapt a 2-wire motor with a couple of resistors and diodes to do the job.
Adapting a non reversing motor takes only a resistor but for it to be able to reverse you need a double setup and diodes to keep it from shorting out.
Old 12-10-2015, 08:22 AM   #15
FortyNiner
FortyNiner's Avatar
Might consider looking here : https://www.apartswarehouse.com
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 12-12-2015, 03:30 PM   #16
221239ford
Lawson, thanks for sending me the motor details and thanks to others with comments. I found a local automotive electric shop who is going to rebuild it for me.
Old 12-14-2015, 05:17 AM   #17
moonraker
moonraker's Avatar
That's the motor that I used in my '39 heater. It's about 1\2 inch longer than stock one so I had to modify blower body to fit it in. I use the stock switch, everything works fine.
moonraker is offline   Reply With Quote
Old 12-14-2015, 05:38 AM   #18
Mafman
Mafman's Avatar
Hi Ted, I'm in the Charlotte area as well, so would you please post about your experience with the automotive electric shop and let us know who it is? Thanks!
Mafman
James Johnson
Mafman is offline   Reply With Quote
Old 12-14-2015, 06:31 AM   #19
oldskool
oldskool's Avatar
I have a good used motor and switch in the swap section
oldskool is offline   Reply With Quote
Old 12-19-2015, 06:13 PM   #20
221239ford
James, I dropped off the motor on Thursday. Will let you know how it works out. Ted
