Old 11-16-2015, 11:04 AM   #1
charles in east texas
charles in east texas's Avatar
Default Gas cut off valve
Is the gas cut off valve suppose to have a spring in it. Charles
charles in east texas is offline   Reply With Quote
Old 11-16-2015, 11:14 AM   #2
jw hash
jw hash's Avatar
Default Re: Gas cut off valve
there is NO spring in any Model A gas shut off valve that I have ever seen.
jw hash is offline   Reply With Quote
Old 11-16-2015, 11:18 AM   #3
Gary Karr
Gary Karr's Avatar
On the early style shut off valves, there is a small spring under the brass screw-on cap.
Gary Karr is offline   Reply With Quote
Old 11-16-2015, 12:04 PM   #4
jrelliott
jrelliott's Avatar
My '28 A has a spring under the cap like Gary Karr says. If the inside is not scored can burnish the two mating surfaces of the cut off with tooth paste after draining the tank. Then clean the cutoff good with lacquer thinner to make sure no residue.
jrelliott is offline   Reply With Quote
Old 11-16-2015, 06:30 PM   #5
Where can I purchase a spring. Bratton does not show a spring. Charles
Old 11-17-2015, 03:53 PM   #6
I found a spring at the local hardware store.
Charles
