Old 11-12-2015, 06:52 PM   #1
Chevford
Chevford's Avatar
Default Need help 41 Tudor radiator replacement
For those of you that have done one.
Could I please get some insight.
Looks like the car was built around the radiator!
Thanks for any help
John
Chevford is offline   Reply With Quote
Old 11-12-2015, 07:18 PM   #2
cmbrucew
cmbrucew's Avatar
Default Re: Need help 41 Tudor radiator replacement
Drain water, Remove radiator splash pan, hoses, shroud "if your car has one"
and a bolt and nut and springs on each side. Then remove the fan. Then lift it out.
You may need some help as it is heavy.
The only hint would be use a cherry picker or engine hoist with a sling thru the crank hole.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 11-13-2015, 12:59 PM   #3
Chevford
Chevford's Avatar
I thought the fan had to be taken off
Thanks
Old 11-13-2015, 01:03 PM   #4
42merc
42merc's Avatar
Reading comprehension is a gift.
Put a piece of cardboard between the fan & radiator before removing the fan.
42merc is offline   Reply With Quote
