Old 11-09-2015, 05:27 PM   #1
6lucky13
6lucky13's Avatar
Default Water Pumps...rebuild or new?
I noticed a burning rubber-type smell when I ran my ’37 engine (in ’36 Cabriolet). I finally traced it to the right water pump not turning causing the generator belt to rub on the pump pulley. Assuming a failed pump (belt was appropriately tensioned since left pump turned), do I rebuild the pumps (Skip or ?) or purchase new? I would appreciate your comments/thoughts.
Kerry
6lucky13 is offline   Reply With Quote
Old 11-09-2015, 05:52 PM   #2
39portlander
39portlander's Avatar
Default Re: Water Pumps...rebuild or new?
Skips, support an American automotive restorer
39portlander is offline   Reply With Quote
Old 11-09-2015, 05:54 PM   #3
green50
green50's Avatar
Do a search.There was another water pump topic just started ("Time for new water pumps") lots of responses.
Gene
green50 is offline   Reply With Quote
Old 11-09-2015, 06:56 PM   #4
jrvariel48
jrvariel48's Avatar
Skip Haney!
jrvariel48 is offline   Reply With Quote
Old 11-09-2015, 07:04 PM   #5
jacob smith
jacob smith's Avatar
skip
Ford
jacob smith is offline   Reply With Quote
Old 11-09-2015, 08:10 PM   #6
old guy rich
old guy rich's Avatar
Got my two back from Skip about a week ago, (50 Merc) look brand new and pulleys turn smooth as glass. Great work. Old guy.
old guy rich is offline   Reply With Quote
Old 11-09-2015, 09:10 PM   #7
48 coupe
48 coupe's Avatar
had skips on for 10 years or so don't rememberr for sure . still pumpin good.
48 coupe is offline   Reply With Quote
Old 11-10-2015, 05:04 AM   #8
willowbilly3
I've always found that water pumps are about the only part that rebuilt is as good as a new one. Maybe better nowdays since they use a lot better seals than the NOS ones would have.
willowbilly3 is offline   Reply With Quote
Old 11-10-2015, 06:34 AM   #9
JM 35 Sedan
JM 35 Sedan's Avatar
Most of the new pumps available from Drake, Carpenter, Speedway, and others, are coming from China and if your main thought is to save a few $$'s, they may be your choice.
Fryers is the only source, to my knowledge, for new USA mfg'd pumps with original part numbers stamped in the castings to satisfy judging standards. This may be the most expensive way to go, but the quality is good.
Skip Haney is your best choice if you want a set of original cast in part number pumps rebuilt to perfection by a true American craftsman who backs his work 100%. He has rebuilt at least six sets of pumps for me (3 sets of '35's & 3 sets of '37-'48) and I could not be happier with the quality and performance of these pumps.
You must decide what is best and most important to you.
John
Old 11-10-2015, 06:38 AM   #10
39portlander
Originally Posted by JM 35 Sedan View Post
Skip Haney is your best choice if you want a set of original cast in part number pumps rebuilt to perfection by a true American craftsman that backs his work 100%.
Kerry, Need we say more
Old 11-10-2015, 08:50 AM   #11
MGG
MGG's Avatar
I installed a pair of the Chinese pumps before I new better. Had some trouble because they are of poor quality. I would go the Skip rebuild route next time.
MGG is offline   Reply With Quote
Old 11-10-2015, 11:46 PM   #12
Lenny51
Lenny51's Avatar
Just had my water pumps rebuilt on my 51 at Skips working great & run real smooth
Lenny51 is offline   Reply With Quote
Old 11-11-2015, 03:25 PM   #13
6lucky13
6lucky13's Avatar
Thanks to everyone who responded. I'll have the pumps rebuilt by Skip Haney.
