Old 10-28-2015, 07:49 PM   #1
'46Ford
'46Ford's Avatar
Default Lights go on and off
I have a 46 ford sedan, all stock, 6 volt system. The lights, all of them, headlights, tail lights, dash will all come on and function for a while, approximately 5 minutes, then they will turn off for several seconds and then come on. This will be repeated sporadically. I have a generator on the vehicle. The amp meter on the dash shows charging and appears to be functioning okay. Any ideas on where to go with this. Could it be the regulator? I have checked all connections, everything seems tight. Thanks for any help.
'46Ford is offline   Reply With Quote
