Old 10-12-2015, 06:06 PM   #1
adileo
adileo's Avatar
Default Painting cast head
I'm thinking about painting my cast heads on the car with a small brush. I think I can do it but, I am concerned about the spark plug area. My orginial thought was to put old plugs in and paint, but I don't think I can get the entire plug area.
Anyone do this? Any suggestions?
Ps: I have bolts and would be painting them same as head
adileo is offline   Reply With Quote
Old 10-12-2015, 06:11 PM   #2
NealinCA
NealinCA's Avatar
Default Re: Painting cast head
In the past, I have cut little tape circles for the plug holes. I was spraying the engine, but I think it would work fine for brushing as well.
NealinCA is offline   Reply With Quote
Old 10-12-2015, 06:20 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
Don't know what you mean by "entire plug area".
Nothing wrong with using old plugs painting only to the plug washer.
Should not paint under the washer.
Old 10-12-2015, 06:33 PM   #4
adileo
adileo's Avatar
Neal that is one beautiful engine. While your tape looks like a perfect fit - I'd be afraid paint would get behind the tape.
51merc - ok I think that is best safest way for me to go.
One more question. I cleaned off all the dirt on the head, but around the plug is really tough to clean. Any suggestions for cleaning that area (really the base of the plug at the plug washer.
Old 10-12-2015, 06:37 PM   #5
JSeery
JSeery's Avatar
Small roterty wire brush?
Old 10-12-2015, 07:37 PM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
I've used old plugs for painting heads with brush or spray. Has always worked well for me. Still have the painted plugs in my plug collection incase I need to do more painting .
John
Old 10-13-2015, 07:13 AM   #7
chap52
chap52's Avatar
Aluminum foil woks great to protect small parts you don't want to get paint on. Much easier to remove than tape.
chap52 is offline   Reply With Quote
Old 10-13-2015, 07:39 AM   #8
adileo
adileo's Avatar
As the norm with this site all great advise.
Additional tips/tricks will be much appreciated.
Old 10-13-2015, 07:40 AM   #9
BABAR40
BABAR40's Avatar
There may also be small corks available at hobby or craft stores for the plug holes. I would put an aluminum foil boot on the cork so particulate wouldn't fall into the piston bore. But having said all that, I would put an old set of spark plugs in and paint. Have fun!
BABAR40 is offline   Reply With Quote
Old 10-13-2015, 08:24 AM   #10
adileo
adileo's Avatar
For others that may want to paint heads. Just read on Bill Hirsch paint site, one should wait two weeks after painting (before driving) for paint to cure.
Old 10-13-2015, 08:31 AM   #11
Joe Immler
Same as JM 35. I used plugs and the saved them. Also, I have a bunch of the chrome head nut covers to help around them. They clean up well after using them.
Joe Immler is offline   Reply With Quote
Old 10-13-2015, 08:31 AM   #12
GOSFAST
GOSFAST's Avatar
We have some paper plugs for the spark plug holes that are used for delivering newly built units.
They fit directly into the plug holes and come in 14mm (PG-420) and 18mm (PG-421) for various plug sizes! Easily removed when necessary.
Thanks, Gary in N.Y.
P.S. They are mfd by Pioneer Products, should be relatively easy to find. We get them by the "hundred's"! See the photo below.
GOSFAST is offline   Reply With Quote
Old 10-14-2015, 12:09 AM   #13
Bluebell
Neal, what sort of paint is that? That is pretty!
Bluebell is offline   Reply With Quote
Old 10-14-2015, 07:10 AM   #14
adileo
adileo's Avatar
I purchased the paint yesterday. I went with Roy Nacewicz. While his site really specializes in Ford bolts, he also sells the proper color paint for our flatties.
Roy answered the phone and I was pleasently surprised how knowledgeable he was about ford flatheads. I probably spent a good half hour talking engine paint & about head bolts vs studs.
The call ended with him saying "feel free to call anytime with questions and even if your not in the market to purchase anything"
A true professional, a pleasure to chat with and a very knowledgeable individual. I highly recommend if your in the need of bolts or engine paint, give him a call.
Old 10-22-2015, 07:49 AM   #15
adileo
adileo's Avatar
Thumbs up Re: Painting cast head
For anyone who is thinking about painting the engine on the car. Please see photos attached.
I was more than a little nervous on how this would come out but....I found if your very careful, take your time and tape off any areas that are close to areas needing paint, the process is fairly easy. Using old spark plugs and good cleaning prep is very important.
Old 10-22-2015, 07:57 AM   #16
countrysquire
countrysquire's Avatar
That came out great. I just did a similar thing to my engine and it made all the difference under the hood.
countrysquire is offline   Reply With Quote
Old 10-22-2015, 09:23 AM   #17
Ralph Moore
Ralph Moore's Avatar
Another good option for plug holes are silicone plugs, they are inexpensive and reusable.. Available at powder coating supply houses( such as Eastwood ). I have a whole kit that works well for all types of painting.
Ralph Moore is offline   Reply With Quote
Old 10-22-2015, 07:11 PM   #18
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I remember years ago a friend who was a stripper had a 40 Merc with a hot engine, his engine was black and he had painted flames coming out of each spark plug holes. Really sharp. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 10-22-2015, 08:15 PM   #19
MDC
MDC's Avatar
Could he have been a custom painter or was his name Magic Mike?
MDC is offline   Reply With Quote
Old 10-22-2015, 08:30 PM   #20
sunshine
sunshine's Avatar
I used pennys . They pop right out when you crank it over. SUNSHINE
sunshine is offline   Reply With Quote
