Old 10-03-2015, 10:56 AM   #1
jonf
Default ZINC additives and hardened valve seats necessary?
I'm rebuilding a pretty much stock 59AB and I have just two questions (so far).
1. With a mild regrind cam and new lifters and stock springs, should I use a zinc additive for break in?
2. Should I installed hardened valve seats?
jonf is offline   Reply With Quote
Old 10-03-2015, 11:04 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: ZINC additives and hardened valve setats necessary?
The factory installed hardened seats
adding additives to some oils can make them less---the oils additive package can clash with additional additives
the low valve spring pressure doesn't load the lifter/cam interface like modern OHV engine
Old 10-03-2015, 11:08 AM   #3
Seth Swoboda
Seth Swoboda's Avatar
Just use Shell Rotella 15W-40 oil and you will be fine.
Seth Swoboda is offline   Reply With Quote
Old 10-03-2015, 11:21 AM   #4
ford38v8
ford38v8's Avatar
Seth, They quietly took it out of Rotella too, as I'm told.
Alan
Old 10-03-2015, 12:38 PM   #5
Mike51Merc
Mike51Merc's Avatar
Unhappy Re: ZINC additives and hardened valve setats necessary?
Here we go with the "oil wars" again.
My opinion, based on as much as I could read on the subject:
Zinc is about cams and lifters, not valve seats (that's the unleaded gas argument).
Flatheads have low valve spring pressures.
Zinc is needed most in overhead valve engines with high spring pressures.
Rotella removed some zinc, but not all of it.
Most antique cars drive less than 2000 miles/year.
It doesn't hurt to have added zinc, it might be catastrophic to have no zinc.
Personally, I run Rotella T (diesel formula) and just for kicks and giggles, I add a pint of STP oil treatment (the blue bottle has zinc).
For break-in I'd use a cam manufacturers' assembly lube and break-in oil additive.
Mike51Merc is offline   Reply With Quote
Old 10-03-2015, 02:03 PM   #6
GOSFAST
GOSFAST's Avatar
If the original block has no seat inserts from Ford we generally install at least 8 for the exhaust valves. The intakes aren't really necessary. I do get some customers that want both however.
With respect to the break-in lubes, we have NOT varied from the days gone by for the cam lube, ALL flat-tappet cams get strictly broken in with "moly", and the rest of the build, mainly rings, is broken in with some "dedicated" break-in oil. There are numerous brands, one we use in particular is the "Brad-Penn" line. This oil is based on the original "Kendall" formula from the Pa. refineries! It is specially formulated for the "break-in" period only. There are others, Lucas, etc.
We actually supply a number of shops in the area with small containers of the "moly" lube, many cam vendors no longer supply this item.
Thanks, Gary in N.Y.
P.S. Here's a shot of some "Brad-Penn" 30 wt, it comes an various weights. Also a shot of machining for the valve seat inserts using a Winona-PH2000 cylinder head machine. Last shot of the Lubriplate ass'y lube we use on the brgs and the containers of "moly" for the cam lobes and lifter bases.
GOSFAST is offline   Reply With Quote
Old 10-03-2015, 04:29 PM   #7
corvette8n
corvette8n's Avatar
Hemmings sells it own zinc rich brand online $54.00 for 6 qts., it ain't cheap.
Old 10-03-2015, 07:47 PM   #8
JSeery
JSeery's Avatar
Zinc additives are available from some cam vendors if you want it. You can buy in individually or in 12 packs.
Old 10-03-2015, 11:09 PM   #9
fordor41
fordor41's Avatar
I use mobil 1 and zinc additive. Mine is an OHV but $14 every 3000 miles for zinc isn't going to break me so why take a chance.
fordor41 is offline   Reply With Quote
Old 10-04-2015, 07:30 AM   #10
JSeery
JSeery's Avatar
"$14 every 3000 miles for zinc isn't going to break me..."
And I believe that the is single quantity price, think I purchased my last case of 12 for around $8 each.
Old 10-04-2015, 08:41 AM   #11
Ol' Ron
Ol' Ron's Avatar
might as well jump in. I use 5-20 oil in a rebuilt engine , I believe in hardened seats in the exhaust and valve rotators for stock and mild cams. I think too much zink is bad , I think 15-40 oil is bad. But that's just my opinion. The beauty of the Flathead is: it works.
Old 10-04-2015, 10:01 AM   #12
VeryTangled
VeryTangled's Avatar
Default Re: ZINC additives and hardened valve seats necessary?
Hi Everyone, I found this post/photo made by FordBarn member Fordors in this thread:
http://www.fordbarn.com/forum/showth...=1#post1166742 Post #21
"How about this display from the 1934 edition of the Century of Progress, Tony? As I mentioned here before Henry dragged his feet and didn't go to Chicago in 1933; but in 1934 this complete Fordor was displayed in cabinets for all to see. The series of photos show everything, for example a lower seat spring assembly was broken down to individual pieces, the radiator as tubes and plates (for the fins) etc. Those were the days! "
Notice the valve seats in the photo!
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 10-04-2015, 10:20 AM   #13
JSeery
JSeery's Avatar
Smile Re: ZINC additives and hardened valve setats necessary?
I agree, but the correct amount of zinc is good, to much zinc is bad. About like everything else in life. I also agree with using the lower weight oils.
Old 10-04-2015, 10:57 AM   #14
prpmmp
Ol' Ron has built more flatheads than Carter has liver pills so if he said to run apple juice in my flathead then apple juice it is!!!Pete
prpmmp is offline   Reply With Quote
Old 10-04-2015, 11:44 AM   #15
GOSFAST
GOSFAST's Avatar
If any of the oils has "Racing" included on the labels it has all the additives already included.
P.S. If it doesn't specifically state "Racing" then it does not contain all the additives. See the photo below here. The "Brad-Penn" below is for break-in ONLY, they do have race oils also!
Old 10-04-2015, 12:33 PM   #16
Ralph Moore
Ralph Moore's Avatar
That is a cool display! I'd love to have that cutaway flathead in my shop too!
Ralph Moore is offline   Reply With Quote
Old 10-04-2015, 12:57 PM   #17
4t8v8
I have used Mobil Delvac 1300 15W-40 in my flatheads and ovh's for years. Never a problem. Soooo - will just keep using it.
4t8v8 is offline   Reply With Quote
Old 10-04-2015, 01:30 PM   #18
supereal
supereal's Avatar
At our shop we replace all valve seats during rebuilding because almost always the original, and some replacement, seats are so worn that there is not enough material left to regrind them.
supereal is offline   Reply With Quote
Old 10-04-2015, 01:47 PM   #19
40 Deluxe
Back in the '50's and early '60's, when flatheads were starting to show their age, it was standard procedure to use plain non-detergent oil for break-in ("to seat the rings"). No zinc in that oil! This oil was used whether the job was a backyard re-ring job or a Ford Authorized Rebuilt complete engine. I never heard of or saw a flat cam from using this oil! Factory fill on new cars may also have been non-detergent; not sure about this. Old leaky oil burners got fed the cheapest oil available and never flattened their cams, either.
Old 10-04-2015, 01:48 PM   #20
Ol' Ron
Ol' Ron's Avatar
It's obvious 15-40 works, but there must be a reason you use it in stead of 10-30 as recommended by the factory. Just because it works, doesn't mean it's right. The reason I use 5-20 is because it makes the bearings run cooler, as more oil passes through them
