Old 10-02-2015, 05:43 PM   #1
30-9
Default Filter or not to filter that is the question
I have a fuel filter prior to my electric pump (back by gas tank). Car runs fine.
What are the advise here - do I need second prior to carb?
Note: no manual pump
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 10-02-2015, 05:45 PM   #2
JonC
Default Re: Filter or not to filter that is the question
No, where would the dirt come from?
JonC is offline   Reply With Quote
Old 10-02-2015, 06:18 PM   #3
39topless
A second filter just prior to carb (or fuel pressure regulator if installed) is a very good idea. Nothing worse than a clogged carb. There is about six or seven feet of steel gas line between the electric pump and the carb that can introduce crude to the fuel. In this case, two really is better than one.
39topless is offline   Reply With Quote
Old 10-02-2015, 08:48 PM   #4
JSeery
JSeery's Avatar
Fuel injected cars normally use only one filter and injectors are very picky about clean fuel. I see no reason you would need a second filter but then again as long as the flow requirements are met it is not going to hurt anything.
Old 10-02-2015, 09:22 PM   #5
Binx
Remember the stone and cartridge filters installed in the carb inlets of the last carbureted engines? The closer, the better.
Lonnie
Binx is offline   Reply With Quote
Old 10-03-2015, 10:29 AM   #6
19Fordy
19Fordy's Avatar
I installed a second filter a second filter near the carb. CLICK on pic. to see it.
Old 10-03-2015, 10:56 AM   #7
FL&WVMIKE
FL&WVMIKE's Avatar
I don't feel that double filtering would hurt anything, unless you were going for judging.
MIKE (mikeburch)
FL&WVMIKE is offline   Reply With Quote
Old 10-03-2015, 12:23 PM   #8
Ralph Moore
Ralph Moore's Avatar
If your still running a mechanical fuel pump you can install a small filter in the glass bowl,
Napa 3039? I think. Add a small spring to keep it in place. And it does not look out of place on a stock flathead.
I'd post you a picture, but I still haven't figured out how to add a pic from my phone.
PM me and I can email it to you.
Sorry, just read the part about no mech pump. ;(
Ralph Moore is offline   Reply With Quote
Old 10-03-2015, 01:12 PM   #9
39topless
To post a photo from your phone, plug your phone into your computer then when you want to reply to the post, go to "go advanced". Then "browse". Your I-phone should show up under your Library photos (if you've downloaded the photos from your phone) or under your Computer. It seems to be easier to download the photos to your computer first.
Old 10-03-2015, 10:01 PM   #10
Ricardo39
Hi, a question for 19Fordy; is that carb a holley 2300? I have one installed in my coupe, with a 239 ci. I barely started it a few times ( is still unfinished ) and IŽll glad to know what metering body and jets you have. Thanks in advance, Ricardo.
Ricardo39 is offline   Reply With Quote
