Old 09-28-2015, 11:41 AM   #1
harleytoprock
Default Drag link to tie rod
My drag link was rubbing the tie rod because the leaf spring was sagging. With the ride height corrected, won't the rods now hit each other when going over a big bump? Thanks
harleytoprock is offline   Reply With Quote
Old 09-28-2015, 11:59 AM   #2
burner31
burner31's Avatar
Default Re: Drag link to tie rod
I should think not, but I'm no expert.
How did you correct the height?
A pic of the area many help.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 09-28-2015, 06:56 PM   #3
Y-Blockhead
Y-Blockhead's Avatar
If they're hitting check your tie rod. The only time mine hit was when I had a bent tie rod.
Old 09-28-2015, 11:45 PM   #4
ian Simpson
Same here, just threw out my bent tie rod.
ian Simpson is offline   Reply With Quote
Old 09-29-2015, 12:53 AM   #5
burner31
burner31's Avatar
Ian:
I'll show you mine if you show me yours.
Keith
Shawnee OK
'31 SW 160-B
Old 09-29-2015, 09:01 PM   #6
ian Simpson
Originally Posted by burner31 View Post
Ian:
Oh, you meant the 57 Chev.
Old 09-30-2015, 12:25 AM   #7
burner31
burner31's Avatar
Ian:
Very sweet car.
Sometimes I find myself torn between which to drive. The A, or the '57.
Guess it depends on my mood.
But since I got the Model A running I find myself making excuses just to drive it.
But I still love my Chevy.
Keith
Shawnee OK
'31 SW 160-B
Old 09-30-2015, 12:32 AM   #8
jw hash
jw hash's Avatar
I have had a couple Model A`s in here that the left steering was bent just a little bit, making the drag link and tie rod rub on each other. I just bent the steering a little and that did the trick.
jw hash is offline   Reply With Quote
Old 09-30-2015, 01:10 AM   #9
pat in Santa Cruz
pat in Santa Cruz's Avatar
if you put a shortened pittman arm on, not only will it steer more easily, but the tie rod and drag link will be further apart
pat in Santa Cruz is offline   Reply With Quote
Old 09-30-2015, 10:00 AM   #10
burner31
burner31's Avatar
Shorting the pitman, I understand will improve the steering, but what types, if any, adjustments are needed?
Steering wheel centering?
Tie rod adjustments?
Toe in/out?
Anything?
Keith
Shawnee OK
'31 SW 160-B
Old 09-30-2015, 01:05 PM   #11
2manycars
2manycars's Avatar
I have shortened pitman arms on 2 cars, and did not neet to make any adjustments at all. Steering wheel is where it always was, tie rod is not effected by drag link.
2manycars is offline   Reply With Quote
Old 09-30-2015, 09:55 PM   #12
ian Simpson
I put a shorter pitman arm earlier this fall. Helped make the steering much easier on my arthritic hands. No adjustment needed, however, checking through all the associated components I have replaced the tie rod, tie rod ends, and all the little parts to replace damaged, missing and worn bits. The only original part from the steering box forward is the drag link which has new internals and grease nipples!
Old 10-01-2015, 12:55 AM   #13
burner31
burner31's Avatar
I've seen the short pitman, and gave it a passing thought, now that it appears it's all a plus, meaning no adjustments/changes/disadvantages.
It seems a no brainer.
I'll put this on my "todo" list for this winter, doing the steering box and new tie rod innards this winter anyway.
Thanks all.
Keith
Shawnee OK
'31 SW 160-B
Old 10-01-2015, 10:45 AM   #14
Fullraceflathead
Fullraceflathead's Avatar
I have a short pitman arm on my '28. There is a drawback but It's not all that bad in my opinion. the 7 tooth steering box will turn a little bit less turning to the left.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
