Old 09-22-2015, 03:24 PM   #1
michaeld1
Default Contaminated Engine Oil - Milky shade to Crankcase oil
When I purchased my "restored" 1930 Model A pickup in 2010, the local ford dealer reported contaminated engine oil (milky shade) at my first oil change. We tracked the issue down to a cracked head - replaced head with a stock freshly machined and magna fluxed head. We did not resurface the block.
I continue to see contaminated engine oil (milky shade) at each oil change. Any ideas where I should start?
Mike
michaeld1 is offline   Reply With Quote
Old 09-22-2015, 03:36 PM   #2
Fullraceflathead
Fullraceflathead's Avatar
Default Re: Contaminated Engine Oil - Milky shade to Crankcase oil
If your lucky it just the Head Gasket Leaking. I'd re check the Torque on all head bolts.
It could also be a crack in the block or head. Most likely it's the Head Gasket.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 09-22-2015, 03:37 PM   #3
1930artdeco
1930artdeco's Avatar
Sounds like the block may not be perfectly flat. That happened to me when I rebuilt my engine. Either that or you did not get all of the water out of the passages.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 09-22-2015, 03:42 PM   #4
CarlG
CarlG's Avatar
If you are typically driving it on a bunch of short jaunts, and never get the engine up to normal operating temperatures and held there for 30-45 minutes, you will have condensation that will result in milky looking oil or residue, especially around the breather cap.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-22-2015, 04:00 PM   #5
andyfresno
Mike,
The milky oil is caused by water in the oil, which obviously you already know.
I had this problem once when I didn't go back and re- torque the head nuts.
Did you take a really good look at the top of the block? Put a straight edge on it?
The next things to consider aren't good - -cracked block, etc.
I always put a can of stop leak in the radiator when I have the head off - -some guys think this can clog things up - -but I haven't had a problem. - -I'd try that before you consider what's next.
Oh - -by the way - -if the stop leak fixes the problem, your oil will still be milky from the small amount of old oil left the engine, but it shouldn't be as bad
andyfresno is offline   Reply With Quote
Old 09-22-2015, 04:08 PM   #6
Keith True
Keith True's Avatar
I would put my money on just the residue from the old oil.There will be a bunch still in the valve chamber and in the dipper tray that won't drain out,plus what was stuck to the insides of the engine.It may take a couple of changes to get it all out.Plus,where you are looking for problems a little bit of water will seem like a lot in your mind.
Keith True is online now   Reply With Quote
Old 09-22-2015, 04:26 PM   #7
andyfresno
yep -could be - -but it should be less milky -
It's a lot of work - -but you could clean out the old oil - drop the pan (there is oil in the splash pans) and take off the value cover - -I think that will get It all - -I'd do that before I pulled the engine - -I guess - - not a fun problem
Old 09-22-2015, 05:30 PM   #8
Mitch//pa
if you want to clean the milk out of a motor get it hot then drain the oil.. with the plug still out pour 2 qts of ATF to clean out the dipper tray. reinstall the oil plug and refill crankcase with ATF. run the motor stationary for 15 minutes. drain the ATF and dump 2qts of motor oil to clear the dipper tray.. refill with motor oil run the car a few miles then drain again and refill youll have a clean motor.
Old 09-22-2015, 09:55 PM   #9
redmodelt
redmodelt's Avatar
Unless I get my T out for a good long run, even in the summer, I often see milky colored oil at the filler hole. I have done all the checking for leaks and just write it off to condensation.
Old 09-22-2015, 09:55 PM   #10
Idaho Brett
Idaho Brett's Avatar
I would think that if you still have "Milk Shake Like Oil", take note of water level in radiator AND oil level on dip-stick. Let the car sit for a few days....then check the water level in the radiator AND check the oil level on the dip-stick.
If the water level has dropped AND the oil level has increased; it would mean you still have a leak some where. (Either a gasket problem, a head/block surface problem or the head is not torqued down)
If the water level AND oil level haven't changed then there is residual water in the oil passages some where.
I just recently went through this "Milk Shake Thing" and pulled the oil pan to get things cleaned up after replacing a leaky head gasket.
Idaho Brett is offline   Reply With Quote
Old 09-26-2015, 08:46 AM   #11
a guy
Had the same problem. Started with head gasket, machined head, new head no luck. Pulled valve cover off and inspected high up in cylinders. Found non-repairable crack between number 2 and 3. Got new reconditioned block and overhauled entire engine. I used flash light and mirror. Camera probe would be better. Good luck. Try simple things first.
a guy is offline   Reply With Quote
Old 09-26-2015, 10:21 AM   #12
Ed in Maine
Don't forget to put a few coats of Permatex head gasket sealer on the block, head and both sides of the head gasket. Torque the head down to 55 ft-lb.s and torque it often during the first startup. Initially run the car five minutes, torque again. Run the car 10 minutes, etc and torque again. You should be retorquing the head until there is no decrease when the car is at full operating temperature. Ed
Ed in Maine is offline   Reply With Quote
Old 09-26-2015, 12:08 PM   #13
Brentwood Bob
Running the motor should drive off the water suspended in the crank case. If the cloudy oil doesn't disappear then look deeper. #12 advice to keep retorquing the head until the head bolts stay tight is right on.
Do you keep the car in a garage, or outside? The motor needs to be run a while each time you use the car. Show and tell, or brief starts won't do the motor much good.
Brentwood Bob is offline   Reply With Quote
Old 09-26-2015, 12:33 PM   #14
Floats
Floats's Avatar
Hi Guys,
Have another look at Mike's first post, he says he bought the car in 2010 and the head was changed then.
Now years later, it surely cant be 'residual milky oil', unless the oil hadn't been changed for 5 years.
Mike,
Was the head ever retorqued after it was fitted?
Regards
Chris
Cape Town
28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Floats is offline   Reply With Quote
