Old 09-13-2015, 08:13 AM   #1
36coupe
36coupe's Avatar
Default Ford 6v coils
I have a bunch of old coils and I was planning on sending one to skip to rebuild as a spare for my 38. I have a brown and a black one both ford script but different in appearance.
Which one should I rebuild?
36coupe is offline   Reply With Quote
Old 09-13-2015, 08:28 AM   #2
48 coupe
48 coupe's Avatar
Default Re: Ford 6v coils
do both. same postage. What they say. A pair and a spare.
48 coupe is offline   Reply With Quote
Old 09-13-2015, 09:15 AM   #3
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
The brown one is the hardest to find......
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 09-13-2015, 09:34 AM   #4
Kube
Super Moderator
Kube's Avatar
The black coil was produced solely for the use of the Detroit Transit System. Questions remain as to whether or not any were eventually "side tracked" and placed in to automotive usage. Thus far, I've not been able to find any documents that would prove that to be the case.
If authenticity matters to you, the brown coil is the way to go.
By the way, the black coil you have requires a unique condenser which are very difficult to procure. That may be a serious consideration when deciding to invest in its rebuild.
Old 09-13-2015, 10:20 AM   #5
36coupe
36coupe's Avatar
Here is another Two I have with old condensers still attached.
Old 09-13-2015, 10:32 AM   #6
36coupe
36coupe's Avatar
The black one might be a Canadian thing.
Old 09-13-2015, 10:56 AM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
The brown one in post #5 does not have the Ford script, so is probanly after market. I think the brown look nice when combined with the brown end caps on the '37-'41 distributors. Not sure what the judges would say about that on the show field, but I could care less about that. Those black coils are interesting. Have not seen many of those. Not sure why it may use a different capacitor, unless it has a different type of mounting. I would definitely get them rewound using components with modern, high temperature rated insulations. Any of those original coils are subject to shorting windings/turns under heated conditions.
John
Old 09-13-2015, 11:25 AM   #8
36coupe
36coupe's Avatar
I wonder if the black ones are from tractors?
Old 09-13-2015, 11:33 AM   #9
JM 35 Sedan
I have some from tractors that do not look like those.
John
Old 09-13-2015, 01:14 PM   #10
Steve Seidl
Steve Seidl's Avatar
Red face Re: Ford 6v coils
Which ever coil you rebuild make sure it fits your distributor first.There are three screw coils and later 2 screw coils.
Steve Seidl is offline   Reply With Quote
Old 09-13-2015, 01:44 PM   #11
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
See something new every day, never seen one of the black ones. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 09-13-2015, 05:04 PM   #12
Kube
Super Moderator
Kube's Avatar
Did you happen to read post #4?
I was not making that up. The black one was made exclusively for the (properly) Detroit Street Railways.
Old 09-13-2015, 05:06 PM   #13
BUBBAS IGNITION
I have seen a couple of those condensors and wondered what they fit........pretty simple mounting....
[email protected]
Old 09-13-2015, 05:07 PM   #14
Kube
Super Moderator
Kube's Avatar
Exactly John...a different mounting.
I have a few of these coils with some NOS condensers. I have always wanted to use one as I like "different" on my restorations. However, "correct" and documented as such has always trumped "different". If and until I might find proof these were utilized in "normal" car production, they will remain in the drawer, unused.
Old 09-13-2015, 05:44 PM   #15
36coupe
36coupe's Avatar
Yes I did read your post and I realize that you are well know for your quality restorations and knowledge.
I find it surprising that 2 I found in Nova Scotia at different times would be that far from home. I've seen a few black ones down this way at swaps and other peoples collections. I actual thought they where more popular than the brown ones.
Old 09-13-2015, 06:38 PM   #16
Kube
Super Moderator
Kube's Avatar
Please understand that Ford was to make 100 of these per day for the Detroit Street Railways for a total of nearly two years. Many of us who have studied these "goofy" little things believe there is no way Railways could have utilized that many of these coils. Thus, the theory is some of these must have gotten in to production or most likely yet, service parts.
As you no doubt realize that while many Ford parts were built in plants outside the USA, many domestic parts were shipped abroad as well. Very often the parts shipped for international consumption were "different" than the USA counter-part. by "different" I mean in design and / or quality level and / or obsolete (for USA), etc.
It does not appear that authenticity is a big concern for you. If I am correct I would suggest you get the brown coil rebuilt as proper condensers are readily available.
Old 09-13-2015, 07:07 PM   #17
36coupe
36coupe's Avatar
Another view of the black ford and and brown aftermarket.
Old 09-13-2015, 07:09 PM   #18
36coupe
36coupe's Avatar
Brown and black ford. F-6 stamped into the black one.
Old 09-13-2015, 07:20 PM   #19
36coupe
36coupe's Avatar
Could the black case have more windings or be heavy duty someway?
Here is a close up of the aftermarket stamp.
Old 09-13-2015, 07:50 PM   #20
Kube
Super Moderator
Kube's Avatar
I think that is exactly the idea (design) with the black one - more windings. I am only guessing here but in 1942, Ford changed the coil design to look a lot like the black one you have AND they moved it away from the front of the engine. Why? My guess is Ford knew (finally figured out) that the location and design of the coils '37 through '41 was not real good. A larger coil (more windings) and moved away from a "heat sink" proved to be a much better design.
