Old 09-12-2015, 08:54 PM   #1
deeprock
Default LB rebuild
So, I finally disassembled my LB engine. Pistons are already .040 over. It will need to be bored. Is .060 a problem? I have domed pistons. Now for the crank shaft... Already had .020 undersized bearings. It should be turned. But now I here finding oversize bearings is next to impossible. Guidance please.
-shad
deeprock is offline   Reply With Quote
Old 09-12-2015, 11:20 PM   #2
Lawrie
Lawrie's Avatar
Default Re: LB rebuild
Bearings are avail ,just look on e/bay.also suppliers have them.
Lawrie
Lawrie is offline   Reply With Quote
Old 09-12-2015, 11:34 PM   #3
f1builder
it is hard to find bearings .40 and over in my experience and they are very expensive. sometimes its cheaper to find another crank.
f1builder is offline   Reply With Quote
Old 09-13-2015, 01:10 AM   #4
Lawrie
Lawrie's Avatar
cranks turn up,I got a free LB engine the other month .030 bore and std crank.
you got to be lucky sometimes.
Lawrie
Old 09-13-2015, 06:45 AM   #5
JM 35 Sedan
JM 35 Sedan's Avatar
Not sure it's the same on the LB's but the builders who post here normally claim that 0.060" over is about the limit on the early 21 stud poured babbitt engines. There have also been a few posts claiming they broke through into the water jacket just under 0.060". Maybe with your block the cylinders will clean up at less than 0.060"
Are the mains and rods both 0.020" under now?
John
Old 09-13-2015, 07:05 AM   #6
flatheadmurre
flatheadmurre's Avatar
A good machineshop can check the wall thickness if its not safe to go with a larger bore sleeve it.
Old 09-13-2015, 07:17 AM   #7
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
.060 bore is no problem, I don't recommend over .060 but I have bore .080 with no problem, also I've bored through at .060 on rusted blocks on the inside of the water jacket. You can find .030 -.040 rod bearings with enough checking and asking questions. Also the 37-38 21 stud has the same crank as the 36LB. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 09-13-2015, 01:07 PM   #8
ford38v8
ford38v8's Avatar
Along with the mixed results as reported above on .60 over, you might consider sleaves and standard pistons from the outset due to the tendency to overheat with thinner water jackets.
Alan
Old 09-13-2015, 09:09 PM   #9
deeprock
Both rods and mains are @ .020" under. Do they make .050 oversized pistons?
Alan, why would you have overheating problems with thinner cylinder wall?
Thanks for the help!
-shad
Old 09-13-2015, 11:26 PM   #10
ford38v8
ford38v8's Avatar
Shad, I can't document the fact, I only remember reading it somewhere, but that was printed in an actual book instead of the internet where everything you read must be true!
I remember the explanation was that thinner walls contribute to hot spots and cavitation, thereby reducing heat transfer. Sounds logical, so I'll go with that!
Alan
Old 09-13-2015, 11:32 PM   #11
Lawrie
Lawrie's Avatar
Talk to EGGE machine about the pistons,I don't think they make 050,but no harm in asking.
lawrie
Old 09-15-2015, 03:42 PM   #12
Lyndon
Lyndon's Avatar
Be carefull with undersize rod bearing journals on a LB or earlier engine. I rebuilt my LB engine about 5 years ago, and had a terrible time locating replacement rod bearings. The rod bearing inserts on that engine are flanged (later flat head rod bearing inserts are not flanged), and even though many of the supplier websites listed them in their catalogs, when I tried to order them they were found to be unavailable. I ended up spending several weeks searching around on e-bay and several different V8 clubs before I found a complete set for my engine, which had the crank bearing journals bored undersize.
Lyndon is offline   Reply With Quote
Old 11-05-2015, 11:33 PM   #13
deeprock
Ok so all my parts are gathered. Started the assembly process, are the connection rod designed to have locking clips for the nuts? This engine was in pieces when I purchased.
Old 11-06-2015, 08:29 AM   #14
Walt Dupont--Me.
I use rod nuts with the slots around the top (like hacksaw slots) there self locking. The rods usually need recondition, the bearings turn in the rods and the crank, those flanged bearings are made for the 32-38. Walt
Old 11-06-2015, 08:36 AM   #15
deeprock
Ok great, the nut on my rods are slotted like you explained. I did have reconditioned
Thanks Walt!
-shad
Old 11-06-2015, 02:00 PM   #16
flatheadkid1
flatheadkid1's Avatar
There is a set available that is -.030crank/+.010rod. Check out Ebay item number 231727318741. If your rods are reconditioned already these will not work. I previously purchased a set from that seller and was pleased with what I received. Haven't used them yet.
flatheadkid1 is offline   Reply With Quote
