#1 |
Do 16 inch wheels really allow a Model A to handle better and give a nicer ride than say 19 inch wheels, disregarding authenticity for the moment?
#2 |
A bit on the ride. Steering may be harder.
#3 |
16's is a CLASSIC RETRO MODEL A LOOK. Slightly harder steering helps us to get STRONGER!----Anything worth anything, IS NOT EASY.
Bill W.
#4 | |
#5 |
Love the green coupe.....are the front and rears different sizes?
#6 |
I think age and condition of tires either 16" or 19" have a large bearing on how a car rides/steers. JMO Paul in CT |
#7 |
#8 | |
![]() Bill W.
#9 |
Must'a had petrified sidewalls!?
#10 |
Won't 19's give you better gas mileage?
And higher speed.
#11 |
Hi Keith,
You are correct BUT 19 inch wheels with 'bicycle' tyres are about the same size as 16 inch wheels with normal car tyres. Hovever fatter tyres must have a bit more friction and drag than thin ones At the end of the day, I think it is much the same. I think your arugment is good for 21 inch wheels as on my 28 RPU.
Regards Chris Cape Town 28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC |
#12 |
Quite new Firestone Deluxe, I must have not checked the pressure for a YEAR!
(DUMB!)![]() Bill W.
#13 | |
My Roadster handles and rides very nicely with 16 inchers!! |
#14 |
i M RUNNING 16 RADIALS 225 75R 16 GOODYEARS, RIDE,HANDLING AND BRAKES ARE MUCH BETTER, BUT GLENN IN CA THINKS THEY MAKE YOUR CAR LOOK FUNNY, MAYBE SO, BUT I WONT SWITCH BACK
#15 |
I have 18" diameter 1932 Ford wheels with 5.50 tires on my Coupe. The ride smoothness is much better, but the steering effort is much greater. Use a shortened Pitman Arm to reduce the steering effort. The rolling diameter of the 18" wheel is approximately 29".
The rolling diameter of a 19" diameter wheel with 5.00/4.75 tires is also approximately 29". Using 6.50 tires on 16 wheels will also have approximately a 29" rolling diameter.
Bob Bidonde |
#16 |
I love stock Model A's, but that chopped green coupe is the balls!
#17 |
How about braking with 16" tires? With more rubber on the road, stopping distances should be much shorter. Are they? Can you still lock up the wheels with 16 inchers?
#18 |
I can lock up all 4 wheels with my 16s and Ted's brake kit. Can't comment from experience on reduced braking distance as my pickup has always had 16s on it.
