Old 09-11-2015, 03:05 PM   #1
Bolts
Bolts's Avatar
Default 48 coupe- sedan coupe vs coupe for 1948
I'm a little confused about a 5 window coupe, business coupe, (plain old) coupe and sedan coupe for year 1948.
I assume what is referred to a 5 window coupe would be the business coupe, maybe and Super Deluxe Sedan Coupe would be the longer top coupe?
The reason I ask is on the La Barron-Bonney site they ask for the model as in sedan coupe or 5 window coupe.
Jeez I'm mixed up! Could someone set me straight on this?
Thanks.
Nothing wrong with it except for the name on the front.
Alex
Bolts is offline   Reply With Quote
Old 09-11-2015, 03:14 PM   #2
Vic Piano
Vic Piano's Avatar
Default Re: 48 coupe- sedan coupe vs coupe for 1948
I would suggest that you contact La Barron-Bonney and get the definition from them. That way there will be no guessing or getting the wrong kit.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 09-11-2015, 03:34 PM   #3
Bruce Lancaster
There are two different coupe bodies...the sedan coupe type uses the wide door from the tudor and has a longer roof allowing a decent back seat. The other type uses the narrow door from the fordor and has a shorter roof that drops down more quickly than the other. Obviously all side panels and headliner are different, for starters.
Bruce Lancaster is offline   Reply With Quote
Old 09-11-2015, 03:36 PM   #4
Bolts
Bolts's Avatar
Good Vic. You're right.
Thanks.
Alex
Old 09-11-2015, 03:38 PM   #5
Bolts
Bolts's Avatar
Thanks for the info Bruce. I didn't know the doors were used on the different models that way.
Alex
Old 09-11-2015, 04:26 PM   #6
48 coupe
48 coupe's Avatar
I always called mine a club coupe. and the short door one a business coupe.
48 coupe is offline   Reply With Quote
Old 09-11-2015, 06:33 PM   #7
waterboychuck
waterboychuck's Avatar
I always heard that if it's a business coupe it has the short doors.
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
Old 09-11-2015, 06:49 PM   #8
MMB
I don't believe LeBarron Bonney recognizes the "business coupe" moniker for the 41-48 series preferring "standard coupe". At least that was my experience with them.
MMB is offline   Reply With Quote
Old 09-11-2015, 08:48 PM   #9
Marvin/TN
Send a message via AIM to Marvin/TN
Some call it a club coupe but correct name is Sedan Coupe actually I think the name is really a coupe sedan
Marvin/TN is offline   Reply With Quote
Old 09-12-2015, 09:04 AM   #10
cmbrucew
cmbrucew's Avatar
I believe short door or long door would be the best all around description.
That should avoid any confusion.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 09-12-2015, 05:57 PM   #11
34pickup
34pickup's Avatar
Bruce
Thats what I have always referred to them as.
Matt 24:36-41
34pickup is offline   Reply With Quote
