Old 09-06-2015, 06:59 AM   #1
Ed Saniewski
Ed Saniewski's Avatar
Default exchanging rear spring u bolts in a 30 Sport Coupe
A friend of mine has stripped threads in both of the rear spring u bolts. He wants to cut a hole in the rumble seat pan to access them for replacement. Is the rear seat pan welded to the sub frame, or can it be unbolted somehow. In my 160-B sedan it is only covered with seat upholstery. I don't think he wants to unbolt the body and lift. Any ideas? Thanks Ed S.
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
http://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 08-20-2017, 11:12 PM   #2
Jeff M
Default Re: exchanging rear spring u bolts in a 30 Sport Coupe
Digging up an old thread, same issue in my rumble seat coupe. What's the process?
Jeff M is offline   Reply With Quote
Old 08-22-2017, 11:03 AM   #3
Jeff M
Any insight on this? How are the reproduction bolts?
Old 08-22-2017, 11:23 AM   #4
Bob from Northport
Bob from Northport's Avatar
The rear seat pan under the rumble area is riveted in. It does not unbolt and come out. But it is riveted to the body, not the frame. I have found some welded, but believe it should only have rivets that would need to be drilled out.
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 08-22-2017, 12:07 PM   #5
Jeff M
Thanks for the reply, I think mine was a converted car so it's bolted in. Is the seat pan the only thing that needs to be removed if that's the case? No trunk lid, etc.?
Old 08-22-2017, 01:12 PM   #6
30Ford
There is a tool that taper cuts the first few threads and gives you a new start
30Ford is offline   Reply With Quote
Old 08-22-2017, 01:24 PM   #7
Jeff M
Mine are bent as well.
Old 08-22-2017, 01:43 PM   #8
larrys40
Ed,
As Bob said the pan was originally riveted on. You would have to grind off the rivit preferably on the bottom side. Not a fun job upside down. Then punch them out and probably re-rivit with pop rivits when putting it back.
I have a sport coupe in the shop right now. I will take a look at it for clearance, but I think removing the pan is the best way. I wouldn't undo the body and disturb rear fenders, body mounts, hood, etc. It would be counter productive.
If there's enough clearance to put a wedge up between the pan and center of the crossmember it my be enough room to wiggle it up and out. Usually not but some have a little more clearance than others.
Larry Shepard
larrys40 is offline   Reply With Quote
Old 08-23-2017, 09:24 AM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
IF you cut a hole, save the old piece, to WELD back in!
Gregg threw away the piece I sawed out, when I put the exhaust heater in Minerva!! (DRAT IT!) Those firewalls are TOUGH, I spent $17.00 for a QUALITY Hole Saw, that would cut it! (I burned up 2 cheep ones, first!)
Bill Drafty
"THE ASSISTANT GURU OF STUFF"
Old 08-23-2017, 07:42 PM   #10
glenn in camino
glenn in camino's Avatar
On all the Model As I've ever had, the Ubolt nuts are on the bottom and easy to get at.
glenn in camino is offline   Reply With Quote
Old 08-23-2017, 07:46 PM   #11
Jeff M
He was talking about replacing the U bolts not the nuts.
