#1 |
Good Evening All, need a little help with locating the front leaf spring bolts. Any one have any photos or part number for those bolts, mine are worn bad. Any help is greatly appreciated. 1 1/2 ton 1941 Ford
#2 |
Part number 355521-S 3/8"-24 x 7" Special square head bolt.
Bob |
#3 |
What bolts where?
#4 |
That is the tie bolt, thank you for that, I am looking for the shackle bolt/bushing/pin, that connects the leaf springs to the shackles. In the front.
There are a total of six of these, three on each spring, square ends with crown nuts on each end. |
#5 |
measure the width and dia. I may have a few, also requires a very thick washer. on 42 up these were changed to a slightly different set up. try chuck's truck in conn, I believe,
#6 |
The length is 4 1/2" tip to tip, with approx 5/8" square ends and approx 1/2" maybe 7/16" dia thread tips where the crown nuts go on. |
