Old 08-31-2015, 07:44 PM   #1
46fordnut
46fordnut's Avatar
Unhappy 6 volt charge
quick question maybe you people can help. i forgot how long it take to charge my 6 volt battery it 640 cca 130 reserve . i think 78 amp hours but cant figure out if this equals 2 days or more. thank you in advance.
if rust were money i would be a billionaire!!
46fordnut is offline   Reply With Quote
Old 08-31-2015, 08:22 PM   #2
Mike B
Default Re: 6 volt charge
Depends on your battery charger and what it's output is...unless you are on a real low trickle charge, 2 days would be way to long, IMO.
Mike B is offline   Reply With Quote
Old 08-31-2015, 08:24 PM   #3
46fordnut
46fordnut's Avatar
only 6 amps from my charger battery started taking 9 amps now down to about 3 amps.
Old 08-31-2015, 08:30 PM   #4
Mike B
Should be getting close, make sure caps are off and check the level...don't want to boil it all off.
Old 08-31-2015, 08:42 PM   #5
46fordnut
46fordnut's Avatar
thank you and every time i charge a battery if it has caps i take them off , then close to the middle and end check my acid level.
