Old 08-24-2015, 10:21 AM   #1
Steve Plucker
Default Les Andrews books concerning errors within...
Les Andrews Books have been out for a few LONG years now. There have been reported of a few to many mistakes within each of the three volumns.
There have been reports to "throw the book away"...NO WAY...These books are to valuable of an asset to the Model A community...This is not my intention...My intention is that there is a lot of complaining about them because of mistakes...OK THEN...lets list them and get Les's opinion on them and settle this once and for all so the newbies coming into the hobby won't, for a better word, screw up on their intitial restoration.
If this is the case, then I will start a thread concerning these mistakes and let's see just how many of us respond and let's see if Les can comment on them and issue out an eratta sheet correcting the errors.
Some of you have made lists of them...let's see them.
You are right, nothing will get done about this issue if we as a group don't step up to the plate and do something about it...complaining is not going to get us anywhere.
So with that, let's step up to the plate, quit complaining, and post your found error or errors if any at all and quit complaining.
Anybody?????
I will run this for a week...you know..."bttt" (back to the top)...and see just where it get's us.
Pluck
Old 08-24-2015, 10:35 AM   #2
Fullraceflathead
Fullraceflathead's Avatar
Default Re: Les Andrews books concerning errors within...
The Oil Pan Torque says 20 Ft LBS!
20 inch pounds maybe at best is more realistic.
I prefer to tighten just snug. One handed with short ratchet.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 08-24-2015, 10:37 AM   #3
bunnyc
bunnyc's Avatar
Good idea. I hope this thread gets a lot of responses.
bunnyc is offline   Reply With Quote
Old 08-24-2015, 10:40 AM   #4
Steve Plucker
We will see...A lot of guys are really afarid to say anything at all and will not comment for fear that someone else will rag on them. That is not what this thread, I hope, is about...It is about the bonified errors within his books that some have complained about over the past few years.
One down...How many more?
Pluck
Old 08-24-2015, 10:41 AM   #5
katy
katy's Avatar
Don' have the book handy, it's out in the shop, but there's the oft quoted one about the wrong torque on the oil pan bolts. IIRC Les says 20 ft-lbs and I understand that it should be 20 in-lbs.
Old 08-24-2015, 10:49 AM   #6
Y-Blockhead
Y-Blockhead's Avatar
Thanks for starting this thread Steve. It will really help the New guys (ME) and the Old (ME again, but not to Model A's). I am going to make notations in my book as members post the errors.
There are a couple of things in the book that I questioned, I just can't remember what they are right now...
Old 08-24-2015, 11:34 AM   #7
Rowdy
Cutting off the motor mount at the angle and only using the section for the frame. I know that some of the repops are/were too thick in that area, but they can still be used without cutting them off. Better choice would be to buy the repop that is made close to the correct thickness. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 08-24-2015, 11:43 AM   #8
Steve Plucker
And I believe that is the one from Snyders...It is somewhat softer and slightly thinner than that of Brattons.
Two down...
Pluck
Old 08-24-2015, 12:07 PM   #9
Mitch//pa
i dont have the book in front of me right now but wasnt there a discrepancy about the lengths of the brake rods?
Old 08-24-2015, 12:08 PM   #10
Y-Blockhead
Would it help to mention the page the error is on also?
Old 08-24-2015, 12:09 PM   #11
Kevin in NJ
Steering sector shaft size is wrong.
The number has moved over in to the Bratton's catalog.
I think the biggest weakness of his book is a lack of dimensions. For example, determining the fit of a tranny gear to the spline shaft. As I recall he states put some oil on the shaft and let it slide down. If it goes down fast then it is worn too much. I had a shaft and a gear where it went down fast but it only had about .001 or .002" of wear total when measured.
I know there were some other things. I started writing details as I found them at one point. The problem is I do not need to reference the book much these days. I have other sources.
His illustrations are wonderful and it is absolutely a must have for your library, but as with all the books you need to check the numbers.
Kevin in NJ is offline   Reply With Quote
Old 08-24-2015, 12:38 PM   #12
Steve Plucker
So point them out Kevin...That is what this is all about...Heck, we do not know what "details" you are talking about!
Pluck
Old 08-24-2015, 12:39 PM   #13
Steve Plucker
I do not know Mitch...Was there? Point it out to us.
Pluck
Old 08-24-2015, 12:40 PM   #14
Steve Plucker
Can you post them for us?
Pluck
Old 08-24-2015, 01:45 PM   #15
Jerry Kzoo
Jerry Kzoo's Avatar
Steve,
Les's book has really helped me in working on my Model A and others in our club as has this forum. I have tried to follow the cotter pin usage chart in Appendix A-3 and I think the Front Brake Plate Assembly should take 8 cotter pins(4 each side) even though my copy of the book says 3.
I am so glad Les took the time to make this manual for guys like me.
Jerry
Jerry Kzoo is offline   Reply With Quote
Old 08-24-2015, 01:54 PM   #16
Y-Blockhead
Pluck
I will... when I recall WHAT they were...
Old 08-24-2015, 02:39 PM   #17
160B
160B's Avatar
This thread can be very useful, but if you post an error include the Title of the Manual, and which printing the error is in and the page.
Les Andrews has published the following manuals:
Model A Ford Mechanics Manual Volume 1
Model A Ford Mechanics Manual Volume 2
Model A Ford Trouble Shooting and Diagnostics
The Service Bulletin for April 1928 page 239 notes the toe in should be set at 3/16" to 1/4" and was changed in the Service Bulletin for Sept 1928 page 282 to 1/16" + or - 1/32".
I have a First printing Model A Ford Mechanics Manual Volume 1 and on page 2-19 the toe in is noted at 3/16 + or - 1/16.
I also have a 2nd printing Model A Ford Mechanics Manual Volume 1 and on page 2-19 the toe in is noted 1/16 + or - 1/32 which is correct per the Service bulletins for Sept 1928 page 282.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
Last edited by 160B; 08-24-2015 at 03:13 PM. Reason: added titles for the three Les Andrews Manuals
160B is offline   Reply With Quote
Old 08-24-2015, 03:10 PM   #18
Rowdy
Jerry, I do not take this as a chance to beat up on the book or Les personally. Almost every technical book has an error or two, most way more than two. Even the Crown and Barrett books I use every day there are errors and as they are found by someone and reported to the companies we get updates to our manuals. Even I have found errors and reported them and they went up the chain and were corrected. Info is forever changing that is one thing that is constant. We received a shipment of 15 new forklifts last week and although they are the same as the 5 we received last year we have encountered new problems over the weekend. I am sure new info will be generated from whatever we find the problem to be. So far it is eluding us. Rod
Old 08-24-2015, 04:17 PM   #19
Tom Endy
Tom Endy's Avatar
Les Andrews has written the most comprehensive and definitive book ever written about the Model A Ford. His mechanics handbook has aided many Model A enthusiasts. The few errors in the book that I have noticed are so minor that they will not lead anyone down the wrong path. There are some areas where he could have provided more detail. This is where others can contribute, rather than detract. Rather than pick Les’ work apart, time could be better spent writing technical articles that compliment and add more information to his articles.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 08-24-2015, 04:32 PM   #20
Larry Jenkins
Well said, Tom.
I think it's a bad idea to critique Les' books. There are sections that are purposely left a little ambiguous because there are things that are just common sense.
I find many areas in the book that are well detailed.
Larry
Larry Jenkins is offline   Reply With Quote
