Old 08-24-2015, 09:25 AM   #1
Johnnydidd
Johnnydidd's Avatar
Default ac on 53 ford victoria
now that I have most of my problems solved with overheating, I need to address heat from the engine radiating into the front seat area. city driving no problem up to 40 mph after that seems to get pretty warm inside on the front seat. I was thinking about insulating the fire wall do I insulate on the inside or the engine compartment or both?
Johnnydidd is offline   Reply With Quote
Old 08-24-2015, 10:29 AM   #2
flatford8
flatford8's Avatar
Default Re: ac on 53 ford victoria
I insulated the fire wall behind the stock pad and the floor and kick panels on a '50 Fordor. I think it helped alot with heat and noise reduction.....MARK
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 08-24-2015, 12:13 PM   #3
48 coupe
48 coupe's Avatar
The more Insulation the better. 200+ temp. in the engine comp. is hard to deal with . I used 3 layers of the felt with aluminum backing. inside on my 48, it helped a bunch I also did the floor boards. lots of heat comes from the exhaust right under the floor.
48 coupe is offline   Reply With Quote
