#1 |
I have a question...., when using a 50/50 mixture of acetone and ATF as a penetrating oil to loosen stuck parts, can the acetone/ATF mixture be stored in a plastic container, or does it have to be a metal or glass container ?? I never used it before, and not sure if it will attack the plastic.
Anybody know for sure ? Thanks, Sal |
#2 |
I have had some in one of those plastic flip top squirty drinks bottles runners use. Your results may vary, test with a small quantity first.
Mart. |
#3 |
I've used it from a plastic pump container without issue.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
#4 |
Thanks for the quick replies Mart and FortyNiner.
Sal |
#5 |
Perhaps try a small thumb pump type oil can.
#6 |
#7 |
I've used it in both metal and plastic containers without issue. As Walt stated, shake before use. It does work well.
#8 |
I had a 5 gallon metal can of acetone that destroyed the plastic pour spout
on the top of the can from fumes I guess. G.M.
www.fordcollector.com |
#9 |
Mixed it in a plastic coffee container, and used a plastic ketchup bottle to squirt into cylinders.
That stuff WORKS!! |
#10 | |
Nobody has ever accused me of being a 'safety nut', but I'm thinking that to my grandkids that could look a lot like a strawberry-kiwi juice drink. This debate brings up the guy who invented the 'universal solvent'. Unfortunately there was nothing he could keep it in..... And lastly, I have had that mix in a 59ab for 3 months and this afternoon I pulled the timing gear cover and cam gear and plan to haul the engine into my shop and see if it will turn. I have had good luck with it and also mmo and acetone.
#11 |
Thanks to everyone for all of the good input.
Sal |
#12 |
My experience was that the bottle i chose was attacked. Acetone will dissolve some plastics.
[FONT=Comic Sans MS] |
#13 |
Good point about safety. No youngsters in my garage, though, so didn't cross my mind.
Mart. |
#14 |
Likewise, I have a mix in one of the condiment squirt bottles that are sold by Wal-Mart or the like. The acetone not dissolved the plastic.
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
#15 |
i had a 4 hp staionary engine with a long time stuck piston i stood it on end fillred yhe cylinder with acetone and put a stick for a wick in it put a couplr propanr torches on it for about 8 hours a nd with a 2 x 4 knocked it out without too much effort had to sleeve it but its been running good for 25 years.it does work
#16 |
A blast from the past. Sure miss Walt.
Gramps |
#17 |
Glass is best but the acetone tends to evaporate over time so more must be added for each use.
#18 |
I have always stored my mix in a plastic oil container. I have never had issues with the plastic melting. I keep the cap sealed as to no acetone evaporates. The concoction works great.
Vic |
