#1 |
In looking at the Drum Taillight light bulb attchments, it appears that the upper attachment is for a single contact bulb and the lower attachment is for a double contact bulb both utilizing stright pins for attachment, I think.
That being the case, just what are the bulb numbers associated with each one? Thanks. Pluck |
#2 |
No, they are both single contact bulbs. The lower one is the tail light and the upper one is the brake light.
I assume you want 6 volt bulbs. The tail light is a #63 (3 cp) bulb. For the brake light you can use an EIKO A-4513 for the original 21 cp brightness, or an #1133 bulb (32 cp) to be brighter, have the brake light seen better. Hope this helps.
Jim Cannon Former MAFCA Technical Director ![]() "Have a Model A day!" |
#3 | |
Thank you for your reply. Pluck |
#4 |
I posted some detailed pictures of the drum sockets in the past. I wonder if a search would still turn them up. I had to repair a couple drum taillight assemblies.
#5 |
Tom, was it Post #5 in this thread?
1929 Tudor since 1962 Feather River A's |
#6 |
