Old 08-06-2015, 04:17 PM   #1
1934calkid
1934calkid's Avatar
Default Can Anyone I.D. This Flathead
Can Anyone I.D. This Flathead ? its is definitely a 49 to 53,it has NOT been bored and has a 3 3/16 bore with a slight lip from the rings on top of the cylinder bore, clean valve springs but it is stuck, so we cant measure stroke yet. and idea from the pictures ? there also seems to be some green original paint on it also, any ideas ? thanks
1934calkid is offline   Reply With Quote
Old 08-06-2015, 04:24 PM   #2
Tony, NY
Default Re: Can Anyone I.D. This Flathead
1CM is 1951 Merc. Paint color is Merc, too (I believe).
Tony, NY is offline   Reply With Quote
Old 08-06-2015, 04:25 PM   #3
Fredb_
Fredb_'s Avatar
I guess I'm looking at the rear camshaft cover plate. I have found those 1CM numbered plates on several Ford V8 motors even though it sounds like a Merc number.
Fredb_ is offline   Reply With Quote
Old 08-06-2015, 04:26 PM   #4
1934calkid
1934calkid's Avatar
thanks tony..........
Old 08-06-2015, 05:30 PM   #5
flatjack9
flatjack9's Avatar
Looks like the crankshaft is out. Why can't you measure the stroke?
Old 08-06-2015, 05:51 PM   #6
1934calkid
1934calkid's Avatar
How do we measure the stroke if crank is out ? And piston are stuck ?
Old 08-06-2015, 06:03 PM   #7
rotorwrench
rotorwrench's Avatar
With the crank out you can measure the counterweight cheeks. Mercs are near 6-inches across and Fords are 5 1/2-inches. It seems like the cam gear covers were made for clearance on the automatic transmissions so either Ford or Mercury might have that cover. It has truck water pumps and many of the later pickup engines were green.
Old 08-06-2015, 06:12 PM   #8
4tford
4tford's Avatar
http://www.flatheadv8.org/boomer/crank.htm an article I wrote a few years ago
4tford is offline   Reply With Quote
Old 08-06-2015, 06:20 PM   #9
skidmarks
skidmarks's Avatar
Size of the oil plugs in the crank is another way to figure out if its ford or mercury. But I have been told thats not always true.
skidmarks is offline   Reply With Quote
Old 08-06-2015, 09:34 PM   #10
1934calkid
1934calkid's Avatar
You guys are all geniuses ! I never would have thought of measuring a counterweight ! Now if I only had the crankshaft that was originally in the block ! Lolololol.......no crank.....
Old 08-06-2015, 09:47 PM   #11
Mike B
Then it's really just a standard bore FH, why would it matter it matter to be ID'ed?
Mike B is offline   Reply With Quote
Old 08-07-2015, 06:26 AM   #12
flatjack9
flatjack9's Avatar
So the stroke will be whatever you want.
Old 08-07-2015, 07:46 AM   #13
Ol' Ron
Ol' Ron's Avatar
Note! Canadian Nerc 4" cranks had the small clean out plug in most of them. Second the blocks were all the same for cars and trucks. However, early blocks had hardened seats in the exhaust up to mid 51, after that they had rotators on the valves.
Old 08-07-2015, 10:44 AM   #14
1934calkid
1934calkid's Avatar
Just curious I guess ???
Old 08-07-2015, 11:24 AM   #15
Bruce Remington
I worked in an engine shop for many years, did all the model A's and the v8 flatheads, did hundred's of em. Best job in the shop. The block IS a Merc block.
Bruce Remington
Bruce Remington is offline   Reply With Quote
Old 08-07-2015, 12:25 PM   #16
rotorwrench
The block IS an 8BA block. There is no difference in the blocks. The only exception is whether it is late with no exhaust stellite seats or early with stellite seats
Old 08-07-2015, 12:45 PM   #17
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by Bruce Remington View Post
I worked in an engine shop for many years.................. The block IS a Merc block.
Bruce Remington
Hey Bruce......Welcome to the 'Barn. You seem to be pretty adamant in your statement about this being a MERCURY block. As rotorwrench aludes-to above, both Ford and Merc blocks '49-'53 are identical. I'm curious as to what you're basing your belief ("block IS Merc") on? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-07-2015, 01:18 PM   #18
tubman
tubman's Avatar
It seems to have Merc water pumps.
Old 08-07-2015, 01:56 PM   #19
34PKUP
34PKUP's Avatar
Nope! Looks like Truck pumps circa 48' and up.
34PKUP is offline   Reply With Quote
Old 08-07-2015, 08:08 PM   #20
Binx
Crap! I was hoping for a 4" Merc crank outcome! I love those stories!
Lonnie
Binx is offline   Reply With Quote
