Old 08-02-2015, 02:47 PM   #1
Brendan
Brendan's Avatar
Default headlight relay
do you run a headlight relay? and where did you put it, could you post a photo? I have been thinking of putting one in my 36 pickup
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 08-02-2015, 03:48 PM   #2
ford38v8
ford38v8's Avatar
Default Re: headlight relay
Brendan, before you do that, test your horns with jumpers to see if a relay is needed. I don't think a '36 has a relay 'cause the horns don't draw that much juice? I believe the '36 horn is adjustable?
In any case, your horn button simply grounds the (pos) wire closing the horn circuit. Relays are normally placed close to the unit, with a heavy gauge hot running to the relay.
Alan
Old 08-02-2015, 03:55 PM   #3
JSeery
JSeery's Avatar
Are we talking headlights or horns?
Old 08-02-2015, 03:58 PM   #4
ford38v8
ford38v8's Avatar
Oh, I read it wrong! Yes, a relay for headlights can work wonders! One relay for high beam, one for low beam, up close by the radiator.
Alan
Old 08-02-2015, 04:06 PM   #5
JSeery
JSeery's Avatar
Mount your relays where you can keep the power runs as short as practical. I mounded mine near the radiator on the frame rail. But, I wanted them to be seen because of the setup I am using, if you are using the plastic ones you might want them more concealed.
Old 08-02-2015, 04:59 PM   #6
Kahuna
Kahuna's Avatar
On a 36 with the stock harness, don't you have to cut into the harness to access the wires to add relays?
Kahuna is offline   Reply With Quote
Old 08-02-2015, 05:24 PM   #7
JSeery
JSeery's Avatar
Yep. I attached a diagram. On a pre-foot dimmer switch you would splice into the high and low beam wires from the lighting switch at the bottom of the steering box.
Old 08-02-2015, 06:59 PM   #8
Talkwrench
Talkwrench's Avatar
I found a big difference after wiring in relays , we did both high and low. even better again fitted direct replacement APF halogen globes.
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 08-02-2015, 07:53 PM   #9
Kahuna
Kahuna's Avatar
Great diagram, J
Thanks
Jim
