Old 07-23-2015, 11:26 AM   #1
KiWinUS
KiWinUS's Avatar
Default 48 Flathead 6 cylinder rebuild parts
Guys I am looking for leads on where to purchase parts to completely recondition a 48 Flathead 6 cylinder . eg. pistons, rings ,wrist pin bushes, rod & main bearings , timing gears , valves , valve guides , valve springs cam bearings , gasket set, water pump ,oil pump & any other parts .
Thanks
Cheers
Tony
KiWinUS is online now   Reply With Quote
Old 07-23-2015, 11:48 AM   #2
jboren
Default Re: 48 Flathead 6 cylinder rebuild parts
Check with Egge.com. You may have to call them. They used to show just about all the parts for a complete rebuild on the 226 but all they are showing online now is the V-8.
I got a .30 over piston for mine from them a few years ago without a problem.
I just checked and they are still showing a rebuild kit in their catalog that you can download. Beware it is nearly 400MB so it takes a few minutes to download even with pretty decent download speeds.
jb
jboren is offline   Reply With Quote
Old 07-23-2015, 06:34 PM   #3
redmodelt
redmodelt's Avatar
Check;
Dennis Carpenter
Sacramento Vintage Ford
yes and even
Mac's
Old 07-23-2015, 07:14 PM   #4
russcc
The first person I would check with is Fred Wilner at Southside Obsolete in Faribault MN. He specializes in NOS Ford engine parts. The drawback to Macs and Dennis Carpenter, from my experience is they are selling imported stuff, as most of the NOS is gone. Another alternative is Tom Hannaford, Then & Now Automotive in Weymouth MA.
russcc is offline   Reply With Quote
Old 07-23-2015, 07:56 PM   #5
48superd
I got my rod and main bearings and cam bushings from NAPA. Joblot Automotive is a good source. Fred Wilner at Southside Obsolete is a good source, also. Mac Van Pelt has a few parts. Perfect Engine in Los Angles has some parts. Skip Haney in Florida can rebuild your old water pump. Rods and mains are available from Federal-Mogul, Federal-Mogul cam bushings # 1089M, Steel piston rings are available from Hastings, Fel-Pro gasket set # FS7524S. In the process of rebuilding one right now for '48 Tudor.
48superd is offline   Reply With Quote
Old 07-27-2015, 12:26 PM   #6
amodel25
amodel25's Avatar
It's been about 15 years ago, but I got all my rebuild parts for my '51 6 cylinder from Kanter. The old stock parts came in the original boxes. No Chinese junk!!
amodel25 is offline   Reply With Quote
Old 07-27-2015, 12:50 PM   #7
Ross F-1
Ross F-1's Avatar
Everything I've heard is that you have to get your WP rebuilt, several places doing it.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
