Old 07-17-2015, 09:58 PM   #1
Plainsman30
Default Radius Ball Question
Hi,
I replaced a rubber ball type radius with the factory style radius. However, I don't know if it fits right. You can see in the picture that there is a gap between the top half of the cap and the bell housing casting. The top half does not seem to fit the contour of the casting very well. Is this the way it is supposed to be or do I need to do some grinding?
Thanks in advance
Mike
Plainsman30 is offline   Reply With Quote
Old 07-17-2015, 10:36 PM   #2
Drive Shaft Dave
Default Re: Radius Ball Question
I think the gap may be a little to wide , make sure the part that goes to the bell housing has the small hole in it. The two cups may be reversed.
Drive Shaft Dave is offline   Reply With Quote
Old 07-18-2015, 08:13 AM   #3
Plainsman30
The little hole is facing up, so the cups are not reversed. I originally thought the felt pad in the bell housing may be holding the top cup down, but that wasn't it. I also checked to be sure the mounting flange on the top cup was flat, but that wasn't it either. Thanks,
Mike
Old 07-18-2015, 08:32 AM   #4
jhowes
Since ford used the rubber ball type in later fords, i was wondering what the opinions are about there use in the model "a". Or is like a white wall/black wall discussion?
jhowes is offline   Reply With Quote
Old 07-18-2015, 08:34 AM   #5
RonC
RonC's Avatar
The rubber ball works well but slightly changes your caster angle which is the vertical angle (front to rear angle) of the king pins.
RonC is offline   Reply With Quote
Old 07-18-2015, 08:50 AM   #6
aermotor
I may be wrong but I thought the rubber ball only went with the later cast caps and not the early caps.
aermotor is offline   Reply With Quote
Old 07-18-2015, 09:05 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Yes, the rubber cap only goes with the thicker cast caps.
I don't think I'd worry about the slight gap in the top cap. Drive the car and see how it goes.
Old 07-18-2015, 10:16 AM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Good idea, Tom, I've seen them "settle" in after driving awhile. And with the springs there, they usually DON'T need the nuts re-tightened.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-18-2015, 10:46 AM   #9
swo4rd
swo4rd's Avatar
I am only thinking out loud here, but you might need to grind down the bolt spacers (little pieces of steel or brass tubing) to get a tighter fit...I have noticed lately that the spacers provided in the kits all need to be ground down a bit.
swo4rd is offline   Reply With Quote
Old 07-18-2015, 11:52 AM   #10
Tom Wesenberg
BTW, I don't see any grease in the picture. I would have packed the ball with grease before assembly.
Old 07-18-2015, 05:36 PM   #11
Plainsman30
Thanks to all who replied. I will try the things suggested.
We did sometimes have a some shimmy at low speed when using the rubber ball, but the shimmy seems to be gone after switching to the factory set up. The ball does sit up higher and closer to the bell housing when using the factory set up compared to the rubber ball.
Mike
Old 07-18-2015, 11:44 PM   #12
roddyb34
roddyb34's Avatar
I'm glad I have seen that pic ,,,it has prompted me to realise that my radius ball clamp springs were in the wrong place ,I recently dissembled the ball clamps and did wonder what action the springs would do seeing as they were clamped between the cups,,,there's a fair chance this would cause a looseness and be contributing to the poor driveability I have experienced ,,,the bolts also were bent slightly back also about half way along the exposed part of the bolt this may suggest that the cups were riding out from the mount thus bending the bolts ,,I may have been lucky not to have had more trouble because of this ,,,,
roddyb34 is offline   Reply With Quote
Old 07-19-2015, 09:32 PM   #13
Plainsman30
glad the picture helped.
Mike
Old 07-20-2015, 10:10 PM   #14
30 Roadster Leon
My thought is that the inside bolt holes through the bell housing are worn down into the bell housing making the bolts appear to be too long. The result being that the nuts do not snug up the spacers to the top radius rod plate/bell housing without getting the nut too far from the cotter pin hole in the bolts. A possible sign of this situation is the bolt turning because the bolt head slot misses the cross pin due the bolt head being sunk into the bell housing.
There is a solution for this problem in the latest issue of one of the national Model A club magazines. It involves making bolt head washers from a specific spring.
I am currently involved with this problem on my Model A...waiting on parts delivery.
This repair is said to be possible without major component removal.
30 Roadster Leon is offline   Reply With Quote
