Old 07-12-2015, 08:53 PM   #1
4ford
Default back up camara
I have a1941 ford coupe and installed a backup camera, right now its hooked to the parking lights cant find mirror's that work on that car so the back up camera works well but with out backup lights I am trying to figure out how to switch the camera on other than the lights?? any on have any thoughts? stock car
thanks!!
4ford is offline   Reply With Quote
Old 07-12-2015, 09:07 PM   #2
1937pickup
Default Re: back up camara
How about a switch that gets activated when you put it in reverse, like a modern back up light switch.
1937pickup is offline   Reply With Quote
Old 07-12-2015, 09:11 PM   #3
4ford
pickup that would be a great idea maybe someone has tried and has pics
thanks
Old 07-12-2015, 10:22 PM   #4
Old Henry
Old Henry's Avatar
You could use a simple cheap mini-toggle switch out of sight but easily accessible under the dash as I have here for my interior lights and electric fuel pump. Get them at Radio Shack.
Old 07-12-2015, 10:44 PM   #5
47 flatbed
47 flatbed's Avatar
I use this same set up on my dump truck has no hole to look out of rear view mirror. I have mine all the time hooked up to switched power and use it as my rear view camera in the dump. Works really well for the last 5 years
47 flatbed is offline   Reply With Quote
Old 07-13-2015, 12:06 AM   #6
expavr
expavr's Avatar
I use a spring loaded switch for the backup light on the truck. Its activated by a shift rod in the shift tower assembly that contacts it when the transmission is shifted into reverse. You would have to fabricate a bracket that can hold the switch in a location where the shift arms or linkages on the transmission will contact it when in reverse.
expavr is offline   Reply With Quote
Old 07-13-2015, 06:36 AM   #7
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I've been wanted to put one of the those back up cameras on my 40 coupe, the side mirrows are useless. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 07-13-2015, 08:18 AM   #8
36tbird
Has anyone done this sort of thing and tied it to your turn signal switch? When I re-do my '40 Sedan Delivery I thought about putting in such a system because lane changing in that thing is a real adventure. It is like driving a cave. I might just have to leave it on all the time like flatbed has done.
36tbird is offline   Reply With Quote
Old 07-13-2015, 08:42 AM   #9
cmbrucew
cmbrucew's Avatar
Expavr
Very nice. Extra attention to detail. I like the oil cups for the shift rails.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 07-13-2015, 08:56 AM   #10
TJ
TJ's Avatar
The simplest and easiest way to do it is with a toggle switch or a separate switch (lever type switch) mounted so it is activated with the reverse lever of the linkage.
Old 07-13-2015, 09:37 AM   #11
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by cmbrucew View Post
Expavr
Bruce
You may not realize the full extent of what expavr has accomplished here. That is a re-engineered shifter to shift an overdrive trans. Quite the GENIUS accomplishment. See the full thread by clicking the link below. DD
http://www.fordbarn.com/forum/showthread.php?t=156620
Click Links Below __
T5 W/TORQUE TUBE
Old 07-13-2015, 07:26 PM   #12
4ford
have to try to make something to fit 3 speed trans
Old 07-14-2015, 04:57 AM   #13
51 MERC-CT
51 MERC-CT's Avatar
Don't really understand the need to have the camera operate only while in reverse. It functions as a rear view mirror and the mirror doesn't get shut off.
Perhaps a consideration for those who are still operating on 6 volts would be a need for a 12 volt power source.
And then for those who don't buy Chinese, 'fo-ged-a-bod-it'
Old 07-14-2015, 08:01 AM   #14
35fordtn
35fordtn's Avatar
A 12 volt power source is no issue on a 6v car. I have on several 6v cars hidden the little module in the link below under the dash to make the cigar lighter 12v to run a GPS or charge a cell phone.
http://www.amazon.com/Power-Inverter...v+12v+inverter
35fordtn is offline   Reply With Quote
Old 09-10-2015, 04:58 AM   #15
cordbob
Metra electronics, Hollyhill florida, sells a device that will switch the video signal from up to four cameras to your screen. It is triggered by a 12+dc input and can be wired to reverse light right/left turn signals etc.
cordbob is offline   Reply With Quote
Old 09-10-2015, 05:16 AM   #16
cordbob
Finally found the item you need called-I-BEAM TE-TSI Turn signal video interface. Metra Electronics 800-221-0932 .Plan to put one on my 35 sedan delivery ,when I finally get it done .
Old 09-10-2015, 05:36 AM   #17
34PKUP
34PKUP's Avatar
And what about vehicles that don't have back up lights and turn signals?
Thought that was the original problem.
34PKUP is offline   Reply With Quote
Old 09-12-2015, 03:48 AM   #18
cordbob
The shift rail switch or steering column add on turn signal switch seem like the way to go. Wiring a reverse camera on all the with the ignition switch will shorten it's life span a bit.
Old 09-12-2015, 10:07 AM   #19
outlaw
IMHO, I would hook it up to a seperate manualy activated switch so that you can turn it on any time that you wanted/needed. If you have trouble seeing out of the right side, I would position the camera at a slight angle to view the right lane & this would be a big help in viewing traffic when you want to change lanes. Bill
outlaw is offline   Reply With Quote
Old 09-12-2015, 03:37 PM   #20
richard crow
back up camars, radial tires ,power steering, power brakes, air cond, i thought we loved old cars for what they were. i can see all that stuff if you drive the car every day as your main ride .or beter yet buy a new car & don,t forget power windows
richard crow is offline   Reply With Quote
