10-10-2010, 01:30 PM | #1 |
Fall 2010 issue Model A Times
10-10-2010, 04:14 PM | #2 |
Re: Fall 2010 issue Model A Times
Great Edition of Model A Times !
I called John and suggested he remind people that when they use a permanently mounted battery maintainer, the EXPOSED NEGATIVE LEAD IS HOT, and should be treated as such, since these things are designed with negative ground in mind. You could weld it to your frame and hurt your battery if it is touching the frame. |
10-10-2010, 04:51 PM | #3 |
