06-27-2015, 02:17 PM | #1 |
'36 ford coupe gas tank removal instuctions?
I need step by step instructions to remove the gas tank from my '36 Ford five window coupe. Please help. Thanks.
06-27-2015, 08:05 PM | #2 |
Re: '36 ford coupe gas tank removal instuctions?
Burgie, there have been numerous posts here on how to remove '35-'36 gas tanks. See if you can find some of these previous posts by doing a search first rather than having someone outline all the steps necessary to remove them again here on this post. If you can't find them, come back and let us know and I will either find them for you or post the information again here.
06-27-2015, 08:26 PM | #3 |
I believe the worst step is lifting the body up a few inches. Nothing like doing... Which I haven't done on a 36
06-27-2015, 08:41 PM | #4 |
John,
I couldn't find previous theads. Can you help me to find them. |
06-27-2015, 08:50 PM | #5 | |
No need to lift body.
06-27-2015, 08:52 PM | #6 |
06-27-2015, 08:56 PM | #7 |
Go to "Search" and type in 36 Gas tank removal. Even a cave man could do it.
06-27-2015, 09:21 PM | #8 | |
http://www.fordbarn.com/forum/showth...ng+35+gas+tank http://www.fordbarn.com/forum/showth...ng+35+gas+tank http://www.fordbarn.com/forum/showth...ng+35+gas+tank http://www.fordbarn.com/forum/showth...ng+35+gas+tank http://www.fordbarn.com/forum/showth...s+tank+removal http://www.fordbarn.com/forum/showth...s+tank+removal Just saw that Tony is posting these as well, so I will hold up on posting more. I am sure there are plenty more to be found but what has been already posted should be enough already. Good luck!
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 06-27-2015 at 09:57 PM. |
06-27-2015, 09:22 PM | #9 |
Just remove the 3 bolts, loosen the tailpipe so you can move it a little. Raise the tank about an inch on the drivers side and slide toward the left fender. There should be enough clearance on the passenger side now for the tank to drop down. It'll drop down on the passenger side enough for you to slide it over towards the passenger side, then the drivers side will drop down and it will be out. All that after the filler neck is off of course.
Tim Carlig |
06-27-2015, 09:29 PM | #10 |
Yes, the filler neck has to come off first. The tank can then be muscled out no problem.
06-27-2015, 09:33 PM | #11 |
06-27-2015, 09:34 PM | #12 |
06-27-2015, 09:35 PM | #13 |
06-27-2015, 09:37 PM | #14 |
