06-19-2015, 08:09 AM | #1 |
no power to headlights
hello
i just wired my headlights and have no power to the lights the horn works fine i repainted the h/l bar so i thought ground i ran a ground wire from a head bolt to the mounting bolt for the headlight still not working tried a test light at socket did not light up the switch on the column seems to be working correctly what do i need to ck from here kevin 1930 model a tudor |
06-19-2015, 08:24 AM | #2 |
Re: no power to headlights
ck for power from the headlight switch directly where it leaves the spider, using the appropriate color code... make sure you test it with the switch in the proper position to correspond with that particular circuit ...
then go further up the circuit... you may find the issue at the conduit sockets... |
06-19-2015, 09:04 AM | #3 |
hello
what i found was the wire clip that holds the light switch body to the steering column was not holding the the switch body tight enough to the column i re bent it to hold it tighter and all is working now kevin 1930 model a tudor 1923 model t roadster p/u |
06-19-2015, 11:00 AM | #4 |
Glad you found the problem. May I make a suggestion? Keep a wire with alligator clips in your car, wiith such a such a set up you would not need to run a wire, much less loosen a head bolt.
I never leave home without one.
Mike Stitt "A business that make nothing but money is a poor business." -Henry Ford |
06-19-2015, 11:55 AM | #5 |
I did use a alligator clip I did not loosen the head bolt thanks for the suggestion kevin |
