Old 06-19-2015, 04:45 AM   #1
ford28roadster
Default leaking tillitson
my tillitson carb. leaks only under this condition. leaks only after running with engine off about 30 drops of gas out of throat. does not leak while running does not leak after the 30 drops even with the gas left on. why ? thanks john
ford28roadster is offline   Reply With Quote
Old 06-19-2015, 06:32 AM   #2
Redbird
Redbird's Avatar
Default Re: leaking tillitson
I just rebuilt mine. You can do it in less than two hours taking your time.
Redbird is offline   Reply With Quote
Old 06-19-2015, 07:21 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Heat soak from no air movement causes the gas to boil and drip out.
