Old 06-17-2015, 02:53 PM   #1
okiedokie
okiedokie's Avatar
Default 46 to 48 wishbones
Are they different.
okiedokie is offline   Reply With Quote
Old 06-17-2015, 04:05 PM   #2
skidmarks
skidmarks's Avatar
Default Re: 46 to 48 wishbones
My knowledge 42-48 are the same with the dip. 48 axle is different that it has a boss for a tube shock. Mercury is the same also. The wheel base difference is made up in a spacer bracket on the frame that moved the entire axle setup foward
skidmarks is offline   Reply With Quote
Old 06-17-2015, 04:05 PM   #3
48 coupe
48 coupe's Avatar
I don't know for sure, but can't see why there would be any diff.
48 coupe is offline   Reply With Quote
Old 06-17-2015, 04:22 PM   #4
JSeery
JSeery's Avatar
21A 3405 Radius Rod is listed as 42-48.
Old 06-17-2015, 06:47 PM   #5
okiedokie
okiedokie's Avatar
Thanks all, thought they would be.
