Old 06-11-2015, 08:10 PM   #1
hotrodfreak
hotrodfreak's Avatar
Default 32 dash pull Knobs ID?
OK 32 Ford experts, Please ID these for me. I removed them long ago,
mostly from an original B car. Number 4 on the right is marked "choke."
hotrodfreak is offline   Reply With Quote
Old 06-11-2015, 08:37 PM   #2
DavidG
DavidG's Avatar
Default Re: 32 dash pull Knobs ID?
The two on the left are not original '32 parts. On the right, the one on top is a Model B choke cable and the one on the bottom is a Model B starter switch cable used for much of the '32 model year in conjunction with a starter-mounted switch. The late Model Bs used the foot-operated V-8 starter switch which was mounted on the steering gear box, rendering the switch activation cable obsolete.
Old 06-11-2015, 11:11 PM   #3
Charlie Stephens
Of course DavidG is right. The second one from the left, looks like a repro choke and fuel mixture adjusting rod from a Model A. What does the other end look like?.
Charlie Stephens
Old 06-12-2015, 12:31 AM   #4
Tudortomnz
Tudortomnz's Avatar
Do not think that choke rod is a Model A [ 2nd left] as there is no indicator 'arm' to show settings, eg. quarter turn open for normal running, etc.
Tudortomnz is offline   Reply With Quote
