Old 05-31-2015, 03:42 PM   #1
Beechtech
Default Rear axle seal
I pulled the rear drum off and the bearing, brakes and drum are full of oil not grease. Is this the seal in the axle housing that is leaking? I also think the bearing pulled apart a little because the drum does not go all the way on now.
Beechtech is offline   Reply With Quote
